.NET
Distanceto and Getdistance Units
2 REPLIES 2
Ron_M
372 Views, 2 Replies
Using either the Distanceto or Getdistance methods returns only decimal values.  This is true regardless of the drawing units.  Is there a conversion for this to feet-inches?
2 REPLIES 2
_gile
in reply to: Ron_M
The type of the value returned by these functions is Double.
Have a look at the Autodesk.AutoCAD.Runtime.Converter.DistanceToString() static method (shared in VB).
Gilles Chanteau
GileCAD
GitHub
Ron_M
in reply to: _gile
That did the trick.  Thank you.
”Boost
