.NET
Distance UCS
3 REPLIES 3
Amremad
409 Views, 3 Replies
Distance UCS
How Can i Get the distance between two base point of any two block in any UCS and WCS
3 REPLIES 3
hgasty1001
in reply to: Amremad
The distance between 2 points it's not affected by UCS change, but you need  the 2 points "living" in the same UCS. Just translate the points to some UCS and calculate the distance as usual.
Gaston Nunez
Amremad
in reply to: hgasty1001
then how can i translate the points to some UCS ?
_gile
amremad_world,
I gave you the same reply as gaston here:
http://forums.autodesk.com/t5/NET/Y-Direction/td-p/4308371/page/2
Y showed you the way to translate points with Editor.CurrentCoordinateSystem in the same thread.
Do you think you'll have better replies when multiplying threads for the same task ?
Do you read the replies I gave you ?
Gilles Chanteau
GileCAD
GitHub
”Boost
