.NET
Displaying WinForm with CommandMethod
12 REPLIES 12
Message 1 of 13
1520 Views, 12 Replies
Hi Everyone,
I've been working with CommandMethod to create some AutoCAD commands that
interact with the user through prompts and messagebox display. Next, I want
to start using Winforms but I can't find any examples and the "trial and
error" approach has been failing me. I have the forms designed but can't
display them. I'm using AutoCAD 2006 and VS2005 Beta 2 on Windows XP SP2.
Any suggestions?
Scott
12 REPLIES 12
Message 2 of 13
Hi Scott,
To display a form simply create an instance of it and call its .Show or
.ShowDialog method.
Bobby C. Jones
http://www.acadx.com
"Homer Simpson" wrote in message
news:4897447@discussion.autodesk.com...
Hi Everyone,
Any suggestions?
Scott
Message 3 of 13
I've been trying to do that but the intellisense won't display the
showdialog or show methods for the instance. The code is inserted below. I
also have one form named 'dataGatheringForm' in the project. Any suggestions
are greatly appreciated.
Scott
using System;
using System.Collections.Generic;
using System.Text;
using System.Windows.Forms;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Windows;
namespace ProfileChecking
public class getData
[CommandMethod("CheckProfile")]
public void ShowForm();
Form dataForm = new dataGatheringForm();
// dataform. intellisense not working as expected...
"Bobby C. Jones" wrote in message
news:4897582@discussion.autodesk.com...
Hi Scott,
.ShowDialog method.
Bobby C. Jones
Hi Everyone,
Any suggestions?
Scott
Message 4 of 13
Remove the semi-colon after this line.
Remember that C# is case sensitive. Your dataForm variable name is not the
same in these two lines.
Bobby C. Jones
Message 5 of 13
Thanks, Bobby!
It was that @#*&% little semicolon!
I was focusing on checking the case of the variables and missed the line
terminator shouldn't be there. You have no idea how much time I already
spent trying to figure out what was wrong. I tried new projects, retyping
rather than cut & paste, etc.
Scott
news:4897756@discussion.autodesk.com...
Bobby C. Jones
Message 6 of 13
Glad to help out Scott. Sometimes that second pair of eyes makes all the
difference in the world!
Bobby C. Jones
news:4897845@discussion.autodesk.com...
Thanks, Bobby!
Scott
Message 7 of 13
Here's a C# example.
Create a new solution with a c# project, add references to
System.Windows.Forms, and the AutoCAD managed DLLS,
then add a new Form to the project using the default name
"Form1".
Then, replace the entire Form1.cs file generated by the IDE
with the code below. Then, build the project and NETLOAD
into AutoCAD, and issue the MODALFORM command.
//////////// Form1.cs /////////////////
using System;
using System.Drawing;
using System.Collections;
using System.ComponentModel;
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace AcadModalFormSample
/// Summary description for Form1.
public class Form1 : System.Windows.Forms.Form
/// Required designer variable.
private System.ComponentModel.Container components = null;
public Form1()
// Required for Windows Form Designer support
InitializeComponent();
// TODO: Add any constructor code after InitializeComponent call
/// Clean up any resources being used.
protected override void Dispose( bool disposing )
if( disposing )
if(components != null)
components.Dispose();
base.Dispose( disposing );
#region Windows Form Designer generated code
/// Required method for Designer support - do not modify
/// the contents of this method with the code editor.
private void InitializeComponent()
this.components = new System.ComponentModel.Container();
this.Size = new System.Drawing.Size(300,300);
this.Text = "Form1";
#endregion
#region AutoCAD-specific functionality
private static Form1 s_ThisForm = null;
// singleton form object is created the
// first time this property is referenced.
private static Form1 ThisForm
get
if( s_ThisForm == null || s_ThisForm.IsDisposed )
s_ThisForm = new Form1();
return s_ThisForm;
[CommandMethod("MODALFORM")]
static public void FormShowCommandMethod()
AcadApp.ShowModalDialog(ThisForm);
#endregion
/////////////// end Form1.cs /////////////////
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
"Homer Simpson" wrote in message news:4897447@discussion.autodesk.com...
Hi Everyone,
Any suggestions?
Scott
Message 8 of 13
>> call its .Show or .ShowDialog method.
In AutoCAD you do not call Show() or ShowDialog()
The interop Application class has methods for displaying
forms, and they should be used instead.
Bobby C. Jones
Message 9 of 13
Thanks Tony, Nice info.
"Tony Tanzillo" wrote in message
news:4898376@discussion.autodesk.com...
"Form1".
using System;
public Form1()
if( disposing )
#endregion
get
return s_ThisForm;
#endregion
Hi Everyone,
Any suggestions?
Scott
Message 10 of 13
I posted the example without seeing your code, and
a bit of explaination about the example may be helpful.
If a member function marked with the CommandMethod
attribute is not static, then AutoCAD is going to create
one instance of the containing class, for each drawing in
which the command is issued.
That means that if you have three drawings open in the
AutoCAD editor, and you issue the CheckProfile command
in each of them, then there will be three instances of your
getData class, one for each open document. Hence, there
will be three instances of your dataGatheringForm created
as well.
That scheme can be extremely useful in cases where the
form binds or couples to document-specific data. If the form
does not couple to document specific data, you may not
want to have multiple document-specific forms, and rather
have a single form that is used in all documents.
The choice of which way to go is largely dependent on the
nature of the form and the application it is a part of.
Just so that everyone knows, the sample I posted shows
how to display a single modal form that is used in every
open document, rather than use multiple document-specific
forms.
Lastly, Bobby's advice regarding showing the form, is not
correct for forms in managed applications loaded into the
AutoCAD process.
Instead of calling ShowDialog() or Show() to display your
form, in AutoCAD you would call the ShowModalDialog()
method of the Apolication object. For a modeless dialog,
there is the ShowModelessDialog() method. There are
several things that these methods do, which are desireable
in the case of AutoCAD-hosted winforms. So, you should
use those in lieu of the aforementioned Form methods.
"Homer Simpson" wrote in message news:4897738@discussion.autodesk.com...
Scott
using System;
using System.Text;
Hi Scott,
.ShowDialog method.
Bobby C. Jones
Hi Everyone,
Any suggestions?
Scott
Message 11 of 13
You are correct Tony. Thanks for pointing that out.
Bobby C. Jones
news:4898361@discussion.autodesk.com...
Bobby C. Jones
Message 12 of 13
Mikko
What are the advantages of using AutoCAD winforms?
Message 13 of 13
If you build a managed assembly that's loaded with
NETLOAD, the point is moot. In that case, any Form
derivative is running in AutoCAD, so you can say they
are all 'AutoCAD winforms'.
wrote in message news:4899861@discussion.autodesk.com...
”Boost
