.NET
.NET
Valued Contributor
0 Kudos
Post 1 of 4
Disable keyboard delete key on autocad loading
236 Views, 3 Replies
03-13-2014 01:49 PM
Does anyone ehere knows how to disable keyboards keys (e.g. delete key, enter key, spacebar key) once autocad load.
Thanks and regards,
SCLuna
I think I found the solutions to do this by implementing
ObjectOverrule
Valued Contributor
0 Kudos
Post 2 of 4
Re: Disable keyboard delete key on autocad loading
03-14-2014 02:04 PM in reply to: scluna
ObjectOverrule
SCLuna
Valued Contributor
1 Kudo
Post 3 of 4
03-14-2014 11:37 PM in reply to: scluna
could you post your key code showing how to realize this?
Valued Contributor
0 Kudos
Post 4 of 4
03-15-2014 07:47 AM in reply to: swaywood
Here is the code I got from reading an article from dev blog but I forgot the link.
Public Class CErase
        Inherits ObjectOverrule
        Public Overrides Sub [Erase](dbObject As DBObject, erasing As Boolean)
            MyBase.[Erase](dbObject, erasing)
            Throw New Autodesk.AutoCAD.Runtime.Exception(ErrorStatus.NotApplicable, "Use DrawingTool Delete command to delete Spaces.")
        End Sub
    End Class
    Shared objEraseOverRule As EraseOverrule = Nothing
    Public Shared Sub PreventErase()
        Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        If objEraseOverRule Is Nothing Then
            objEraseOverRule = New EraseOverrule()
            ObjectOverrule.AddOverrule(RXObject.GetClass(GetType(Entity)), objEraseOverRule, False)
            ObjectOverrule.Overruling = True
        Else
            ObjectOverrule.RemoveOverrule(RXObject.GetClass(GetType(Entity)), objEraseOverRule)
            objEraseOverRule.Dispose()
            objEraseOverRule = Nothing
        End If
    End Sub
SCLuna
