.NET
DIMSCALE problem
1 REPLY 1
macleodjb
424 Views, 1 Reply
DIMSCALE problem
Is it really this difficult to set a dimscale in an existing drawing to the current one?  Geez.  I've been googling for way too long without a result.  Hoping someone here can set me on the right path.  So I have two remaining questions.  #1 - How can I fix the code below to set an existing dim style to be the current one.  I'd like to pass in a name of the Dim Style and have it become active.  #2 - How can I loop through the dim style table to view all the available dim styles.  Thanks in advance.
        <CommandMethod("MyTest")> _
        Public Sub MyTest()
            '' Get the current database
            Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim acCurDb As Database = acDoc.Database
            '' Start a transaction
            Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                '' Open the DimStyle table for read
                Dim acDimStyleTbl As DimStyleTable
                acDimStyleTbl = DirectCast(acTrans.GetObject(acCurDb.DimStyleTableId, OpenMode.ForRead), DimStyleTable)
                For Each objectid As ObjectId In acDimStyleTbl
                    MessageBox.Show(objectid.ToString)
                Next
                '' Commit the changes and dispose of the transaction
                acTrans.Commit()
            End Using
        End Sub
1 REPLY 1
HJohn1
in reply to: macleodjb
You can try this, you can pass a dimension name and scale.
        Public Sub MyTest(ByVal DimName As String, ByVal DimScale As Double)
                Dim DimTblRec As DimStyleTableRecord
                    DimTblRec = CType(acTrans.GetObject(objectid, OpenMode.ForRead), DimStyleTableRecord)
                    MessageBox.Show(DimTblRec.Name)
                Next
                If acDimStyleTbl.Has(DimName) = True Then
                    DimTblRec = CType(acTrans.GetObject(acDimStyleTbl(DimName), OpenMode.ForWrite), DimStyleTableRecord)
                    DimTblRec.Dimscale = DimScale
                    acCurDb.Dimstyle = DimTblRec.ObjectId
                    acCurDb.SetDimstyleData(DimTblRec)
                Else
                    'Add code to handle this
                End If
                acTrans.Commit()
            End Using
        End Sub
”Boost
