.NET
Distinguished Contributor
HJohn1
Message 1 of 11 (878 Views)
DIMSCALE problem
878 Views, 10 Replies
05-13-2013 07:54 AM
Hi, I am having problems with dimension after changing the dimscale.  The user wants to change the dimscale.  The program prompts for the selection of a dimension entity and also for the new dimscale.  The dimscale property of the dimension entity is set to the new dimscale.  The problem is that the entity is not updated on the screen, even after calling the entity draw method.  In VBA there was an Update method, but I can find anything like that in the .NET dimension entity.  Can someone help me with this situation? I will really appreciate your help.
Hi John,
Here is a sample code that I tried with AutoCAD 2012 and the dimension scale took effect correctly.
This is a cleaned up version of your code and most of it are suggestions that DP had already provided.
 <CommandMethod("BR")> _
Public Sub DimensionUpdateMethod()
Dim activeDoc As Document
activeDoc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim ed As Editor
ed = activeDoc.Editor
Dim peo As PromptEntityOptions
peo = New PromptEntityOptions(vbCrLf & "Please select a dimension: ")
peo.SetRejectMessage("Please select dimensions only.")
peo.AddAllowedClass(GetType(Dimension), False)
Dim Id As ObjectId
Dim per As PromptEntityResult
per = ed.GetEntity(peo)
If per.Status <> PromptStatus.OK Then
Return
End If
Dim NewDimScale As Double
NewDimScale = 3.0
Id = per.ObjectId
Using Trans As Transaction = activeDoc.TransactionManager.StartTransaction
Dim BlkTbl As BlockTable
BlkTbl = CType(Trans.GetObject(activeDoc.Database.BlockTableId, OpenMode.ForRead), BlockTable)
Dim BlkTabr As BlockTableRecord
BlkTabr = CType(Trans.GetObject(BlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite), BlockTableRecord)
Dim Ent As Entity
Ent = CType(Trans.GetObject(Id, OpenMode.ForWrite), Entity)
Dim dimension As Dimension
dimension = CType(Ent, Dimension)
dimension.Dimscale = NewDimScale
Trans.Commit()
End Using
End Sub
So, It appears that the issue you are having is specific to AutoCAD Mechanical and there are a few features that do behave differently in the verticals.
http://docs.autodesk.com/AMECH_PP/2014/ENU/index.html?url=files/GUID-7B1C5317-E960-49C8-A2F0-D32E2D6F4BA1.htm,topicNumber=d30e22165
In the above post, please refer to "Special Notes on DIMLFAC & DIMSCALE"
Sorry, I dont have a solution to get it working in AutoCAD Mechanical and an expert in the AutoCAD Mechanical discussion forum might be able to help.
ADN Support Specialist
Balaji_Ram
Message 2 of 11 (837 Views)
Re: DIMSCALE problem
05-16-2013 04:43 AM in reply to: HJohn1
Hi John,
Can you please try using the "DimRegen" command ?
<code>
    Application.DocumentManager.MdiActiveDocument.SendStringToExecute("DIMREGEN ", true, false, false);
    Application.DocumentManager.MdiActiveDocument.SendStringToExecute("REGEN ", true, false, false);
</code>
 The other way to ensure that the update happens is described here:
http://adndevblog.typepad.com/autocad/2013/01/force-autocad-to-update-the-graphics-display-area.html
Balaji
Developer Technical Services
Autodesk Developer Network
HJohn1
Message 3 of 11 (824 Views)
05-16-2013 10:10 AM in reply to: Balaji_Ram
Balaji thank you for your suggestions.  I tried them all and the dimension still is not updated on the screen. What I want to do is something like selecting a dimension from the drawing, opening the properties window and changing the dimension overall dimscale.  The dimension entity is updated immediately after.  Here is my code, if you could say what I am doing wrong I will really appreciate.  Thanks in advance.
Try
	Using Trans As Transaction = HostApplicationServices.WorkingDatabase.TransactionManager.StartTransaction
		peo.AddAllowedClass(GetType(AlignedDimension), False)
		peo.AddAllowedClass(GetType(RotatedDimension), False)
		peo.AddAllowedClass(GetType(ArcDimension), False)
		peo.AddAllowedClass(GetType(RadialDimension), False)
		peo.AddAllowedClass(GetType(OrdinateDimension), False)
		per = Ed.GetEntity(peo)
		If per.Status = PromptStatus.OK Then
			Id = per.ObjectId
		Else
			Return False
		End If
		BlkTbl = CType(Trans.GetObject(Db.BlockTableId, OpenMode.ForRead), BlockTable)
		BlkTblr = CType(Trans.GetObject(BlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite), BlockTableRecord)
		If TypeOf (Ent) Is AlignedDimension Then
			AlignDim = CType(Ent, AlignedDimension)
			AlignDim.Dimscale = NewDimScale
		ElseIf TypeOf (Ent) Is RotatedDimension Then
			RotatedDim = CType(Ent, RotatedDimension)
			RotatedDim.Dimscale = NewDimScale
		ElseIf TypeOf (Ent) Is ArcDimension Then
			ArcDim = CType(Ent, ArcDimension)
			ArcDim.Dimscale = NewDimScale
		ElseIf TypeOf (Ent) Is RadialDimension Then
			RadialDim = CType(Ent, RadialDimension)
			RadialDim.Dimscale = NewDimScale
		ElseIf TypeOf (Ent) Is OrdinateDimension Then
			OrdinateDim = CType(Ent, OrdinateDimension)
			OrdinateDim.Dimscale = NewDimScale
		End If
		Ent.Draw()
		Trans.Commit()
		Trans.TransactionManager.QueueForGraphicsFlush()
		Application.DocumentManager.MdiActiveDocument.SendStringToExecute("DIMREGEN", True, False, False)
        Application.DocumentManager.MdiActiveDocument.SendStringToExecute("REGEN", True, False, False)
		Autodesk.AutoCAD.Internal.LayerUtilities.RegenLayers({Ent.LayerId}, Autodesk.AutoCAD.Internal.LayerUtilities.RegenPending)
	End Using
	Return True
Catch ex As Exception
	 MessageBox.Show(ex.Message, "DimScale Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
Finally
	DocLock.Dispose()
End Try
Valued Mentor
DiningPhilosopher
Message 4 of 11 (820 Views)
05-16-2013 12:44 PM in reply to: HJohn1
You don't need most of that code if you only want to update the dimension scale.
The Dimscale property is a property of the Dimension base type, so you don't need all of that if/then/else business that tests the type and casts it to the concrete dimension type.
Just open the selected object and cast it to a Dimension (you don't have to check it first because you're using AddAllowedClass).
After you cast the selected object to a Dimension, and set its Dimscale, call the GenerateLayout() method.
HJohn1
Message 5 of 11 (797 Views)
05-17-2013 05:58 AM in reply to: DiningPhilosopher
DPhilosopher thank you for your suggestion, the unnecessary code as well.  However, this still is not solving the issue. The screen is updated, but the dimensions are in limbo state.  They are visible on the screen but they can not be selected, even after calling the regen command. Any suggestion on how to solve this issue.
HJohn1
Message 6 of 11 (788 Views)
05-17-2013 01:54 PM in reply to: HJohn1
I forgot to mention that I am using AutoCAD mechanical 2012.
Valued Mentor
DiningPhilosopher
Message 7 of 11 (771 Views)
05-17-2013 07:55 PM in reply to: HJohn1
The code you posted contains a collection of hacks that aren't working, but you didn't bother removing them.
The first hack you need to remove is this:
      Ent.Draw()
Second, don't use the TransactionManager from HostApplicationServices.WorkingDatabase.
Use the active document's Transaction manager, and remove the call to QueueForGraphicsFlush(), since the Transaction takes care of that.
Lastly, get rid of the call to SendStringToExecute() to run the DIMREGEN command.
If you're going to hack by trying various things, and they don't solve the problem, don't leave them in the code.
Balaji_Ram
Message 8 of 11 (754 Views)
05-19-2013 10:58 PM in reply to: HJohn1
Hi John,
            Dim ed As Editor
            Dim Id As ObjectId
                Return
            End If
            NewDimScale = 3.0
            Id = per.ObjectId
                Dim Ent As Entity
                Trans.Commit()
            End Using
        End Sub
http://docs.autodesk.com/AMECH_PP/2014/ENU/index.html?url=files/GUID-7B1C5317-E960-49C8-A2F0-D32E2D6...
Balaji
Valued Mentor
DiningPhilosopher
Message 9 of 11 (749 Views)
05-20-2013 12:12 AM in reply to: Balaji_Ram
Hi Balaji.
In the interest of promoting best practices, you wouldn't cast the DBObject returned by GetObject() to an Entity first, and then to a Dimension. You would just cast it to a Dimension, since you can assume that it is one.
Balaji_Ram
Message 10 of 11 (746 Views)
05-20-2013 12:32 AM in reply to: DiningPhilosopher
Hi DP,
You are right, casting it twice is not needed.
Thanks for correcting that.
Balaji
