.NET
dimension text problem
1 REPLY 1
tdaniel14
274 Views, 1 Reply
I am using (dimension.measurement.tostring) to put dimension text in a textbox. My problem is that the dimensions are architectural units but when I fill the textbox, the text is in decimals. How can I keep the actual text that is displayed on the dimension? Thanks!
1 REPLY 1
in reply to: tdaniel14
Well, you cannot use dimension.measurement and expect the desciptive text, which is a formatted value expression. would have replied sooner, but i just ran across your post.
”Boost
