.NET
Active Contributor
brianaubert
Message 1 of 8 (378 Views)
Dimension Association with VB
378 Views, 7 Replies
06-19-2012 11:27 AM
Hi All,
How do you Associate a dimension to a line using VB. I have not had any results searching for an example of this.
Thank you,
Brian
Ok, I understand, but to create extension dictionary to set associativity
will be spend a lot of work
Here is simple way:
 [CommandMethod("assocdim")]
public void CreateAssocDim()
Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
PromptEntityOptions peo = new PromptEntityOptions("\nSelect line: ");
peo.SetRejectMessage("\nYou have to select line only!");
peo.AddAllowedClass(typeof(Autodesk.AutoCAD.DatabaseServices.Line), true);
PromptEntityResult res = ed.GetEntity(peo);
if (res.Status != PromptStatus.OK) return;
ObjectId id = res.ObjectId;
using (Transaction trans = db.TransactionManager.StartTransaction())
try
Autodesk.AutoCAD.DatabaseServices.Line ln = trans.GetObject(id, OpenMode.ForRead) as Autodesk.AutoCAD.DatabaseServices.Line;
Point3d p1 = ln.StartPoint;
Point3d p2 = ln.EndPoint;
Point3d txpt = p1;
Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("dimassoc", 2);
doc.SendStringToExecute("_dimlinear end " + p1.X.ToString() + "," + p1.Y.ToString() + "," + p1.Z.ToString() +
" end " + p2.X.ToString() + "," + p2.Y.ToString() + "," + p2.Z.ToString() + " " +
txpt.X.ToString() + " " + txpt.Y.ToString() + "," + txpt.Z.ToString() + " ", true, false, false);
trans.Commit();
catch (System.Exception ex)
MessageBox.Show(ex.ToString());
 If this is not enough so  say me about
~'J'~
Hallex
Message 2 of 8 (368 Views)
Re: Dimension Association with VB
06-19-2012 12:27 PM in reply to: brianaubert
Take a look at this code, not sure about if this helps, though
 http://forums.autodesk.com/autodesk/attachments/autodesk/152/24647/1/Parametric%20VB%20Net%20Code.tx...)
~'J'~
Active Contributor
brianaubert
Message 3 of 8 (363 Views)
06-19-2012 12:45 PM in reply to: brianaubert
Thanks for the response Hallex. I'll take a look at that.
I'm not looking for parametrics, just normal entities and associative dimensions.
I came across a post about reactors and using LISP, that I'm currently trying to hack something together in VB to operate with reactors. I'm not sure how this will turn out though.
Brian
Hallex
Message 4 of 8 (356 Views)
06-19-2012 02:00 PM in reply to: brianaubert
Here is simple way:
                try
                    Point3d txpt = p1;
                    trans.Commit();
~'J'~
Valued Mentor
jeff
Message 5 of 8 (346 Views)
06-19-2012 04:23 PM in reply to: Hallex
Does setting the DIMASSOC variable do wht you need?
You can also find your answers @ TheSwamp
Hallex
Message 6 of 8 (335 Views)
06-19-2012 09:22 PM in reply to: jeff
Hi Jeff
The DIMASSOC variable doesn't affect creation of the associative dimension
usual way, unfortunately
~'J'~
Active Contributor
brianaubert
Message 7 of 8 (329 Views)
06-20-2012 06:07 AM in reply to: brianaubert
Thank you Hallex !
As you already know, I'm sure, that worked.
Nice and simple.
I've read many of your other posts to peoples questions and pick up on many things. Your a good guy to have on here.
I've been with Autocad since v2.17 and have programed with it extensively, but this .Net stuff is a real challenge to get the hang of.
Makes me feel like a Knob / Newbie again.
Brian
Hallex
Message 8 of 8 (325 Views)
06-20-2012 06:25 AM in reply to: brianaubert
Brian, thanks for your warm words
I'm happy if I can help,
Happy coding :smileyhappy:
~'J'~
