.NET
Different ways of reading a document database
3 REPLIES 3
DiogoSantos
338 Views, 3 Replies
I'm getting a problem regarding getting a document database. I've tested two alternatives:
Alternative1
doc = autoCadApp.DocumentManager.Open(fullpath);
autoCadApp.DocumentManager.MdiActiveDocument = doc;
doc.LockDocument(DocumentLockMode.Write, null, null, false);
Database db = doc.Database
Alternative2
Database db = new Database(true, false);
db.ReadDwgFile(fullpath, FileShare.ReadWrite, false, string.Empty);
Because what I'm trying to do is modify the xref path of documents, and when i detach the xref and then attach the newer xref, if i access the database from the alternative 1, I don't get any error and the xref is updated correctly. But when I use the alternative number 2, when I attach a newer xref i get and ePermantlyErased exception. Shouldn't that be the same? By the way, I need to open the document silently that is why I'm using alternative number 2.
Thanks and kind regards,
Diogo
3 REPLIES 3
Ed.Jobe
in reply to: DiogoSantos
post your code for alt 2
Ed
How to post your code.
DiogoSantos
in reply to: Ed.Jobe
I was doing something wrong, I've already corrected it.
Besides doing the code of alternative 2, i was still openning the document, and for that i was getting exceptions related to conflicts.
Thanks anyway.
Diogo
Ed.Jobe
I figured it was something like that.
Ed
”Boost
