Just out of curiosity, what's the difference between acedPostCommand and acedCmd?
Solved by Alexander.Rivilis. Go to Solution.
This is a completely different functions:
1) The first asynchronous - the second synchronous
2) The first takes as a parameter only string - the second strings, doubles, array of doubles, etc.
3) The first requires the final " " or "\n" - the second does not.
But both functions require PInvoke in .NET 🙂
Facebook | Twitter | LinkedIn
@bjhuffine wrote:
How does this vary from Editor.Command()? Is it basically a wrapped implementation of acedCmd?
acedCmd is the same as Editor.Command()
acedPostCommand is similar (but not the same) as Document.SendStringToExecute()
acedPostCommand send command only to active document (Application.DocumentManager.MdiActiveDocument)
Document.SendStringToExecute() send command to any opened document.
More on this can probably tell only Autodesk specialists.
