.NET
Did ADT 2004 support .NET?
4 REPLIES 4
279 Views, 4 Replies
What if anything can be done when using ADT 2004?
<%= Clinton Gallagher
NET csgallagher AT metromilwaukee.com
URL http://www.metromilwaukee.com/clintongallagher/
4 REPLIES 4
NathTay
You can use the ActiveX API.
Regards - Nathan
Thanks Nathan. That's it? Any source of documentation? Am I correct to
assume then the ObjectARX help files for .NET being distributed by
csharpbird are not going to be useful unless I upgrade from 2004?
<%= Clinton
wrote in message news:5222336@discussion.autodesk.com...
Regards - Nathan
You will not be able to use csharpbird's ObjectARX help files. Pretty much
the only thing that will be usefull to use is acad_aag.chm located in the
/help/ directory of your AutoCAD installation and the .NET COM automation
docs from MSDN.
Tim
http://tjriley.infogami.com/pyacaddotnet
"clintonG" wrote in message
news:5222779@discussion.autodesk.com...
<%= Clinton
Regards - Nathan
Good enough for now thank you.
<%= Clinton
"Tim Riley" wrote in message
news:5222899@discussion.autodesk.com...
docs from MSDN.
Tim
<%= Clinton
Regards - Nathan
”Boost
