.NET
dialog response time
1 REPLY 1
quigs
291 Views, 1 Reply
Hi there,
I have a dialog with lots graphic items and the response time for
refreshing was very slow, sometime 2-3 seconds.  I have
re-wrote it so only certain parts update when they are needed,
say when a value changes & this has helped, but there is still a
very visible lag when re-freshing.
Basically I want to know if there is another less memory consuming
process than re-fresh, or can you increase the available memory to
the pallet, then dispose of it when completed?  Another way I haven’t
though of.
Kind regards,
Maritn.
My name is Martin.. 😄
1 REPLY 1
quigs
in reply to: quigs
Hi there,
I had some similar issues back in the early days when I had a lot of Gui objects in my forms.  I have experianced this in other aspects though like when using a data grid view.  The only way I could improve it was to enable double buffer on these objects.
”Boost
