DGN Purge
I have some problems in my office that some drawing got "infected" with DGN elements.
I've found the DGNPurger utility on the Autodesk knowledge and it works fine with on drawing.
I want to create a simple loop that will open all my drawings and run the "DGNPurge " command on it.
I have created my main loop but when using the doc.SendStringToExecute nothing happened.
I thought of adding the dll as a reference to my project and simply calling the command internally but I could not find the internal main command.
I would appreciate any help on the issue.
Solved by _gile. Go to Solution.
Thanks.
I have no good explanation as to Why I did NOT search the Autodesk Exchange before.
I found there the DWG Purger tool and it worked Great for me.
Thanks (Again).
in batch purge is there any option that file will be saved on same folder or replace the file same folder
if we select from multiple folder for purge than after purge it will be saved on multiple folder
