.NET
Developer Questions (ObjectArx, Visual Studio 2010, etc.)
4 REPLIES 4
tarikpeterson
655 Views, 4 Replies
I am attempting to create an ASP.NET web application (C#, VS 2010) that will load a floor plan (.dwg file) and dynamically place a "marker " of some type on the floorplan to identify the location of some object not shown in the original drawing.
I do not want the user to need to have AutoCAD loaded on their computers for this to work. Is this possible?
Thanks in advance
4 REPLIES 4
arcticad
in reply to: tarikpeterson
You would need some way of modifying the file directly,
By using RealDWG
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=770257
or Open DWG
http://www.opendwg.org/
(defun botsbuildbots() (botsbuildbots))
norman.yuan
Even you have RealDwg lisenced to run at the web server end, you still cannot present a *.DWG to a user with a ASP.NET application, that is, user cannot interact with a *.dwg file visually in a browser.
To make a pure web application, you need to publish a *.dwg into *.dwf file and embed "Autodesk Design Review" browser plug-in in a web page. However, I am not sure if the plug-in can post back to the web server with user input, so that the backend web server can use RealDwg to modify the corresponding *.dwg file according to the recieved user input.
Norman Yuan
Drive CAD With Code
minhasp
how to call another acad function (example : TRIM) in my C++ function ?
thanks !
WebEquipped
Take a look at the following Component I use on our web site:
http://www.woutware.com/cadlib4.0.html
You may find what you need with it.
”Boost
