I am using a dllimport from accore.dll, but the entry point for the method in the dll differs between 32-bit and 64-bit version of AutoCAD. How can I check whether the AutoCAD application is a 32- or 64-bit version, i.e. the dll is 32- or 64-bit?
Solved by Alexander.Rivilis. Go to Solution.
Solved by _gile. Go to Solution.
public static bool IsX64() { if (IntPtr.Size == 4) return false; else return true; }
Sample of using: http://forums.autodesk.com/t5/NET/Can-t-find-ModelessOperationWill-Start-Event-in-Dot-net/m-p/344769...
Other example: http://forums.autodesk.com/t5/NET/Save-a-password-protected-drawing-without-password-with-VB-NET/m-p...
Facebook | Twitter | LinkedIn
@_gile wrote:
is less verbose and quite self explanatory.
Totally agree!
Hi
I didn't know about the IntPtr.size, so thank you for that information. But in my case I can't use this since I can't get IntPtr.size directly in a class where the dllimport is happening. You have to be whithin a method to use it.
Instead I used conditional compilation symbols and I compile one dll for 32-bit and one for 64-bit. By using the conditional compilation symbols the correct part of the code is compiled for each build.
Why? Did you watch the examples to which I referred?
Sample that demonstrate common source code for different AutoCAD version and Platform (32 or 64 bit):
using System; using System.Runtime.InteropServices; using System.Windows.Forms; using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.ApplicationServices; using AcAp = Autodesk.AutoCAD.ApplicationServices; [assembly: CommandClass(typeof(Rivilis.HookESC))] namespace Rivilis { public static class HookESC { static int AcadVer = AcAp.Application.Version.Major; // For AutoCAD 2007 - 2012 64 bit [DllImport("acad.exe", CharSet = CharSet.Unicode, CallingConvention = CallingConvention.Cdecl, EntryPoint = "?acedRegisterFilterWinMsg@@YAHQ6AHPEAUtagMSG@@@Z@Z")] private static extern int acedRegisterFilterWinMsg2012x64(WindowHookProc callBackFunc); [DllImport("acad.exe", CharSet = CharSet.Unicode, CallingConvention = CallingConvention.Cdecl, EntryPoint = "?acedRemoveFilterWinMsg@@YAHQ6AHPEAUtagMSG@@@Z@Z")] private static extern int acedRemoveFilterWinMsg2012x64(WindowHookProc callBackFunc); // For AutoCAD 2007 - 2012 32 bit [DllImport("acad.exe", CharSet = CharSet.Unicode, CallingConvention = CallingConvention.Cdecl, EntryPoint = "?acedRegisterFilterWinMsg@@YAHQ6AHPAUtagMSG@@@Z@Z")] private static extern int acedRegisterFilterWinMsg2012x32(WindowHookProc callBackFunc); [DllImport("acad.exe", CharSet = CharSet.Unicode, CallingConvention = CallingConvention.Cdecl, EntryPoint = "?acedRemoveFilterWinMsg@@YAHQ6AHPAUtagMSG@@@Z@Z")] private static extern int acedRemoveFilterWinMsg2012x32(WindowHookProc callBackFunc); // For AutoCAD 2013 64 bit [DllImport("accore.dll", CharSet = CharSet.Unicode, CallingConvention = CallingConvention.Cdecl, EntryPoint = "?acedRegisterFilterWinMsg@@YAHQ6AHPEAUtagMSG@@@Z@Z")] private static extern int acedRegisterFilterWinMsg2013x64(WindowHookProc callBackFunc); [DllImport("accore.dll", CharSet = CharSet.Unicode, CallingConvention = CallingConvention.Cdecl, EntryPoint = "?acedRemoveFilterWinMsg@@YAHQ6AHPEAUtagMSG@@@Z@Z")] private static extern int acedRemoveFilterWinMsg2013x64(WindowHookProc callBackFunc); // For AutoCAD 2013 32 bit [DllImport("accore.dll", CharSet = CharSet.Unicode, CallingConvention = CallingConvention.Cdecl, EntryPoint = "?acedRegisterFilterWinMsg@@YAHQ6AHPAUtagMSG@@@Z@Z")] private static extern int acedRegisterFilterWinMsg2013x32(WindowHookProc callBackFunc); [DllImport("accore.dll", CharSet = CharSet.Unicode, CallingConvention = CallingConvention.Cdecl, EntryPoint = "?acedRemoveFilterWinMsg@@YAHQ6AHPAUtagMSG@@@Z@Z")] private static extern int acedRemoveFilterWinMsg2013x32(WindowHookProc callBackFunc); private static int acedRegisterFilterWinMsg(WindowHookProc callBackFunc) { if (AcadVer >= 19) { if (IntPtr.Size == 4) return acedRegisterFilterWinMsg2013x32(callBackFunc); else return acedRegisterFilterWinMsg2013x64(callBackFunc); } else { if (IntPtr.Size == 4) return acedRegisterFilterWinMsg2012x32(callBackFunc); else return acedRegisterFilterWinMsg2012x64(callBackFunc); } } private static int acedRemoveFilterWinMsg(WindowHookProc callBackFunc) { if (AcadVer >= 19) { if (IntPtr.Size == 4) return acedRemoveFilterWinMsg2013x32(callBackFunc); else return acedRemoveFilterWinMsg2013x64(callBackFunc); } else { if (IntPtr.Size == 4) return acedRemoveFilterWinMsg2012x32(callBackFunc); else return acedRemoveFilterWinMsg2012x64(callBackFunc); } } // hook message filter callback function [UnmanagedFunctionPointer(CallingConvention.Cdecl)] public delegate int WindowHookProc(ref Message msg); private static WindowHookProc callBackFunc = null; private static int WindowsHook(ref Message msg) { if (msg.Msg == 0x0100 && msg.WParam == (IntPtr)0x1b) { // MessageBox.Show("ESC pressed"); // <- your's action // acedRemoveFilterWinMsg(callBackFunc); // <- unregister callback } return 0; } [CommandMethod("SetHookEsc")] public static void SetHookEsc() { callBackFunc = new WindowHookProc(WindowsHook); acedRegisterFilterWinMsg(callBackFunc); } [CommandMethod("UnsetHookEsc")] public static void UnsetHookEsc() { if (callBackFunc != null) acedRemoveFilterWinMsg(callBackFunc); } } }
