.NET
Detecting New and Delete Layers
1 REPLY 1
rhinton
191 Views, 1 Reply
Does anyone have procedure for detecting when a new layer is created and when a layer is deleted?
1 REPLY 1
cadMeUp
in reply to: rhinton
You can monitor the 'ObjectAppended' and 'ObjectErased' events of a Database. In your event handler check to see if the passed in object is of type LayerTableRecord, then you know if the object being added or erased is a Layer and you can take some kind of action. In the ObjectARX dist, look under ..\samples\dotNet\EventsWatcher for some samples of monitoring Database events.
”Boost
