Hi
The questions refer to an out-of-process program and a system with multiple Autocad versions installed.
Q1: How do we detect the last run Autocad version?
Somewhere between 2004 and 2008, the system registry doesn't point to the last run version any more, but points
instead to AcLauncher.exe which, presumably' has the info.
The question is: How to get the actual path to or the version of, the last-run Acad.exe?
Q2: How does one detect which Autocad version is currently running?
Q3: How does one detect the Autocad version of a .dwg file?
Quite a mouthfull, but with your help I hope to find the solutions.
alex
Here is the answers to questions 2 and 3
Public Sub getACAD() Dim ProcessList As System.Diagnostics.Process() Dim Proc As System.Diagnostics.Process ProcessList = System.Diagnostics.Process.GetProcesses() For Each Proc In ProcessList If UCase(CStr(Proc.ProcessName)) = UCase("acad") Then ' FOUND RUNNING COPY End If Next End Sub
http://cadpanacea.com/node/359
header AutoCAD Version
AC1027 AutoCAD 2013
AC1024 AutoCAD 2010,2011,2012
AC1021 AutoCAD 2007, 2008, 2009
AC1018 AutoCAD 2004, 2005, 2006
AC1015 AutoCAD 2000, 2000i, 2002
AC1014 AutoCAD Release 14
AC1013 AutoCAD Release 13
AC1009 AutoCAD Release 11, 12
AC1006 AutoCAD Release 10
AC1004 AutoCAD Release 9
AC1003 AutoCAD 2.6
AC1002 AutoCAD 2.5
Function is2010(ByVal filename As String) As Boolean 'Return False Dim rtnCheck As Boolean = False If isFileInUse(filename) Then filename = createTempFileName(filename) End If Dim objReader As IO.StreamReader Dim txtContents As String ' Check if File Exists If IO.File.Exists(filename) Then objReader = IO.File.OpenText(filename) 'Read all the Text in the File Do While objReader.Peek <> -1 txtContents = objReader.ReadLine() ' MsgBox(txtContents.Substring(0, 6)) If txtContents.Substring(0, 6) = "AC1024" Then rtnCheck = True End If Exit Do Loop ' Don't forget to close the file objReader.Close() objReader = Nothing End If Return rtnCheck End Function
Thank you Arcticad.
is2010() looks just what I need. I'll just translate it to C# and try it.
Re: your sub getAcad(): OK, we found a running acad, now how do we detect which version it is?
Look at http://through-the-interface.typepad.com/through_the_interface/installation/ and check function GetAutoCADKey.
Also if you use function getACAD (by articad) you can get full path to acad.exe, i.e. Proc.MainModule.FileName
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
arcticad, here is your function translated to C# and beefed-up a little:
public string[] getRunningAcadVersions() { List<string> result = new List<string>(); Process[] processList = System.Diagnostics.Process.GetProcesses(); foreach (Process proc in processList) { if (proc.ProcessName.ToString().ToUpper() == "ACAD") { FileVersionInfo versionInfo = proc.MainModule.FileVersionInfo; int versionMajor = versionInfo.FileMajorPart; int versionMinor = versionInfo.FileMinorPart; string version = versionMajor.ToString("X") + "." + versionMinor.ToString("X"); result.Add(version); } } return result.ToArray(); }
May it help others.
Awesome.
I wasn't aware of the CurVer key.
I kept using Win32API.FindExecutable(".dwg") and it pointed to AcLauncher.exe.
Now it's OK
Thank you, Alexander, and Thank you, arcticad.
@alex_b wrote:
...I wasn't aware of the CurVer key...
Alex! It is very old solution as far as I remember since AutoCAD R14.
