.NET
Distinguished Contributor
alex_b
Message 1 of 8 (745 Views)
Detect Autocad version - three questions
745 Views, 7 Replies
02-14-2013 11:38 AM
Hi
The questions refer to an out-of-process program and a system with multiple Autocad versions installed.
Q1:  How do we detect the last run Autocad version?
       Somewhere between 2004 and 2008, the system registry doesn't point to the last run version any more, but points
       instead to AcLauncher.exe which, presumably' has the info.
       The question is: How to get the actual path to or the version of, the last-run Acad.exe?
Q2: How does one detect which Autocad version is currently running?
Q3: How does one detect the Autocad version of a .dwg file?
Quite a mouthfull, but with your help I hope to find the solutions.
alex
arcticad
Message 2 of 8 (737 Views)
Re: Detect Autocad version - three questions
02-14-2013 12:04 PM in reply to: alex_b
Here is the answers to questions 2 and 3
    Public Sub getACAD()
        Dim ProcessList As System.Diagnostics.Process()
        Dim Proc As System.Diagnostics.Process
        ProcessList = System.Diagnostics.Process.GetProcesses()
        For Each Proc In ProcessList
            If UCase(CStr(Proc.ProcessName)) = UCase("acad") Then
                ' FOUND RUNNING COPY
            End If
        Next
    End Sub
http://cadpanacea.com/node/359
header     AutoCAD Version
AC1027     AutoCAD 2013
AC1024     AutoCAD 2010,2011,2012
AC1021     AutoCAD 2007, 2008, 2009
AC1018     AutoCAD 2004, 2005, 2006
AC1015     AutoCAD 2000, 2000i, 2002
AC1014     AutoCAD Release 14
AC1013     AutoCAD Release 13
AC1009     AutoCAD Release 11, 12
AC1006     AutoCAD Release 10
AC1004     AutoCAD Release 9
AC1003     AutoCAD 2.6
AC1002     AutoCAD 2.5
 Function is2010(ByVal filename As String) As Boolean
        'Return False
        Dim rtnCheck As Boolean = False
        If isFileInUse(filename) Then
            filename = createTempFileName(filename)
        End If
        Dim objReader As IO.StreamReader
        Dim txtContents As String
        ' Check if File Exists
        If IO.File.Exists(filename) Then
            objReader = IO.File.OpenText(filename)
            'Read all the Text in the File
            Do While objReader.Peek <> -1
                txtContents = objReader.ReadLine()
                '     MsgBox(txtContents.Substring(0, 6))
                If txtContents.Substring(0, 6) = "AC1024" Then
                    rtnCheck = True
                End If
                Exit Do
            Loop
            ' Don't forget to close the file
            objReader.Close()
            objReader = Nothing
        End If
        Return rtnCheck
    End Function
(defun botsbuildbots() (botsbuildbots))
alex_b
Message 3 of 8 (708 Views)
02-14-2013 07:06 PM in reply to: arcticad
Thank you Arcticad.
is2010() looks just what I need. I'll just translate it to C# and try it.
Re: your sub getAcad(): OK, we found a running acad, now how do we detect which version it is?
Moderator
Alexander.Rivilis
Message 4 of 8 (697 Views)
02-14-2013 10:34 PM in reply to: alex_b
Look at http://through-the-interface.typepad.com/through_the_interface/installation/ and check function GetAutoCADKey.
Also if you use function getACAD (by articad) you can get full path to acad.exe, i.e. Proc.MainModule.FileName
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
alex_b
Message 5 of 8 (692 Views)
02-14-2013 11:00 PM in reply to: alex_b
arcticad, here is your function translated to C# and beefed-up a little:
public string[] getRunningAcadVersions()
			List<string> result = new List<string>();
			Process[] processList = System.Diagnostics.Process.GetProcesses();
			foreach (Process proc in processList)
				if (proc.ProcessName.ToString().ToUpper() == "ACAD")
					FileVersionInfo versionInfo = proc.MainModule.FileVersionInfo;
					int versionMajor = versionInfo.FileMajorPart;
					int versionMinor = versionInfo.FileMinorPart;
					string version = versionMajor.ToString("X") + "." + versionMinor.ToString("X");
					result.Add(version);
			return result.ToArray();
 May it help others.:smileyhappy:
alex_b
Message 6 of 8 (680 Views)
02-15-2013 02:42 AM in reply to: Alexander.Rivilis
Awesome.
I wasn't aware of the CurVer key.
I kept using Win32API.FindExecutable(".dwg") and it pointed to AcLauncher.exe.
Now it's OK
Thank you, Alexander, and Thank you, arcticad.
Moderator
Alexander.Rivilis
Message 7 of 8 (675 Views)
02-15-2013 02:53 AM in reply to: alex_b
alex_b wrote:
...I wasn't aware of the CurVer key...
Alex! It is very old solution as far as I remember since AutoCAD R14.
alex_b
Message 8 of 8 (668 Views)
02-15-2013 03:02 AM in reply to: Alexander.Rivilis
Shame on me!
