.NET
Demand load from a server.
1 REPLY 1
198 Views, 1 Reply
This may be a stupid question but I decided I should ask before I try to do
it. I've read about demand loading .NET dll's in the registry and I was
wondering if those dll's need to be on the local machine or if I can have
them sitting on a server somewhere? I'd much rather just replace a dll on a
server than having to distribute and installer to each individual.
Tim
1 REPLY 1
You'd probably run into some .NET Security issues. you'd need to alter the security permissions on each machine that you intend to run the file on.
There is a command line tool for doing that, though, so it should be easy.
Something like "caspol.exe -machine -quiet -addgroup 1 -url file://MyServer/* FullTrust" should do it.
you can find caspol in c:\windows\microsoft.net\framework\version\
You'll have to check the syntax, I just got that from the 2.0 beta2 version, so it might different for 1.1. Message was edited by: Elscimar
”Boost
