.NET
Distinguished Contributor
area51visitor
Message 1 of 10 (473 Views)
Deleting Wipeouts
473 Views, 9 Replies
03-04-2013 03:44 AM
Is this correct?
namespace BCCDELWIPOUT
    public class DraftingTools
        [CommandMethod("BCC:WOUT")]
        public static void BCCDELETEWIPOUT()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Transaction tr = db.TransactionManager.StartTransaction();
            using (tr)
                BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                foreach (ObjectId objId in bt)
                    BlockTableRecord btr = objId.GetObject(OpenMode.ForRead) as BlockTableRecord;
                    foreach (ObjectId btrObjId in btr)
                        Entity ent = btrObjId.GetObject(OpenMode.ForRead) as Entity;
                        if (ent is Wipeout)
                            ent.UpgradeOpen();
                                ent.Erase();
            tr.Commit();
- Brian
"Very funny, Scotty. Now beam down my clothes."
bcinnv wrote:
...Don't think this was always exposed to the API, correct?...
IMHO class Wipeout is exposed with AutoCAD .NET API since AutoCAD 2008.
bcinnv wrote:
I just don't know the right way to collect the Wipeouts... as you can see in my code...  I'm doing something wrong but not sure what.  One thing is I don't think I have to ent.UpgradeOpen, I think I can just ent.erase but I'm crashing so there must be something else wrong.
Try replace code:
using (tr)
tr.Commit();
with:
using (tr)
tr.Commit();
Hallex
Message 2 of 10 (453 Views)
Re: Deleting Wipeouts
03-04-2013 05:24 AM in reply to: area51visitor
No,
Wipeout is nothing but closed lwpolyline
with number of verices more than 3 items,
with every bulged segments,
so you can check all these properties to make
sure if you select wipeout
area51visitor
Message 3 of 10 (445 Views)
03-04-2013 06:22 AM in reply to: area51visitor
Thanks again buddy!
- Brian
Moderator
Alexander.Rivilis
Message 4 of 10 (441 Views)
03-04-2013 07:17 AM in reply to: Hallex
Oleg! Are you sure??? Wipeout is Wipeout:
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
area51visitor
Message 5 of 10 (443 Views)
03-04-2013 07:20 AM in reply to: area51visitor
Thanks Alexander.  Don't think this was always exposed to the API, correct? Might be why the suggestion.  I'm using 2012 Civil 3D... think it will work...
- Brian
Moderator
Alexander.Rivilis
Message 6 of 10 (435 Views)
03-04-2013 07:29 AM in reply to: area51visitor
Try replace code:
using (tr)
tr.Commit();
with:
using (tr)
     tr.Commit();
Hallex
Message 7 of 10 (414 Views)
03-04-2013 12:13 PM in reply to: Alexander.Rivilis
I knew that thanks
But why this way it's not working this way?
(ssget "_X" '(( 0 . "wipeout")))
area51visitor
Message 8 of 10 (409 Views)
03-04-2013 12:17 PM in reply to: area51visitor
Thanks Alexander you were correct! The placement of the TR was the problem.  Updated code below:
// delete wipeouts
            using (tr)
                BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForWrite) as BlockTable;
                    BlockTableRecord btr = objId.GetObject(OpenMode.ForWrite) as BlockTableRecord;
                        Entity ent = btrObjId.GetObject(OpenMode.ForWrite) as Entity;
                        if (ent is Wipeout)
                            ent.Erase();
                } tr.Commit();
- Brian
area51visitor
Message 9 of 10 (404 Views)
03-04-2013 12:37 PM in reply to: Hallex
Thanks! That was the way I did it in Lisp. I have decided to convert 10 years of lisp routines I've collected / created into C#, somewhat to learn, but also because I like the better performance with .net.  There is such little material about C# out there than there was .lsp it's considerably harder, but always enjoy a challenge :smileyhappy:
Thanks for the help Hallex! Always appreciated.
- Brian
Valued Contributor
swaywood
Message 10 of 10 (218 Views)
03-06-2014 05:41 PM in reply to: area51visitor
now i am doing the same work , convert 10-years of lisp to c#.
