.NET
Delete specific Block
4 REPLIES 4
raghulan
655 Views, 4 Replies
Hello Guys,
 I coudnt find this online.
I have a handle for a specific block.
I want to delete using the Handle.
Here is what I tried but its not working..please advice.
DocumentLock doclock = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.LockDocument();
            using (Transaction tn = Global.variables.db.TransactionManager.StartTransaction())
                try
                    ObjectId obj = convert_handle_to_objectid(handle);
                    BlockReference Block = (BlockReference)(tn.GetObject(obj, OpenMode.ForWrite));
                    Block.Erase();
                    tn.Commit();
                catch (Autodesk.AutoCAD.Runtime.Exception ex)
                    tn.Abort();
                    MessageBox.Show(ex.StackTrace);
            doclock.Dispose();
 Nothing happens when I run this.
Raghulan Gowthaman Cert IV TAA, B.E,.
Senior Technical Consultant | Developer - R&D
A2K Technologies Sydney
Web : www.a2ktechnologies.com.au
www.civil3dforum.com | www.e4forums.com
www.zcodia.com.au
www.raghulangowthaman.com
4 REPLIES 4
mzakiralam
in reply to: raghulan
You can try following link where deletion of a block is discussed:
http://forums.augi.com/showthread.php?135845-Delete-block
_gile
I don't know anything about the convert_handle_to_objectid method but what about using:
ObjectId id;
if (db.TryGetObjectId(handle, out id))
    // open and erase the DBObject here (no need to cast into a BlockReference)
else
    // unable to convert the handle into an ObjectId
Gilles Chanteau
GileCAD
GitHub
raghulan
in reply to: _gile
Thanks Mate,
 Here is what I tried, nothing happens.
                try
                    ObjectId id;
						DBObject bowner = tn.GetObject(obj, OpenMode.ForWrite, false) as DBObject;
						bowner.Erase(true);
					else
                    tn.Commit();
                    Global.variables.ed.Regen();
                    tn.Abort();
doclock.Dispose();
 I am trying to delete a block.
I tried few other as well still the same issue.
Also I have the same issue with moving blocks. where I am able to move other object but not blocks.
Any Help would be great.
www.zcodia.com.au
_gile
Try this way:
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            try
                using (doc.LockDocument())
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    ObjectId id;
                        DBObject obj = tr.GetObject(id, OpenMode.ForRead);
                        if (obj is BlockReference)
                            try
                                obj.UpgradeOpen();
                                obj.Erase();
                            catch
                                MessageBox.Show("Unable to erase the BlockReference");
                                throw;
                        else
                            MessageBox.Show("The object is not a BlockReference, it's a " + obj.GetType().Name);
                    else
                        MessageBox.Show("Unable to convert Handle to ObjectId");
                    tr.Commit();
                MessageBox.Show(ex.Message + ex.StackTrace);
            catch (System.Exception ex)
Gilles Chanteau
GileCAD
GitHub
”Boost
