.NET
Delete Palette from AutoCAD Tool Palette
4 REPLIES 4
2810 Views, 4 Replies
I wan´t to delete a palette from Autocad Tool Palette. How can I do?
thanks,
Ane
4 REPLIES 4
Balaji_Ram
Hello Ane,
Sorry, There is no direct way to remove the tool palette.
The "ToolPaletteManager.Remove" method does not work and we have already logged this.
As a workaround, you may consider removing the catalog item from the .atc file since it is an XML file and can therefore be parsed / modified by your application but is not recommended.
Balaji
Developer Technical Services
Autodesk Developer Network
khoa.ho
ToolPaletteManager class was moved from acmgd.dll to AcTcMgd.dll in AutoCAD 2013 with some new classes and methods updated. But the API for tool palette is not comprehensive with many missing features. It should have some easy generic methods like Create(), Remove(), Load(), Unload() for tool palettes.
-Khoa
in reply to: Balaji_Ram
Sorry, always i forget to replay...
Thanks for replying, then I have to use another solution.
Ane
Hello @Balaji_Ram,
I have stumbled upon this issue also; where can I catalog item from the .atc?
Thanks in advance.
Derek
”Boost
