.NET
.NET
_ane_
Message 1 of 4 (749 Views)
Delete Palette from AutoCAD Tool Palette
749 Views, 3 Replies
12-07-2012 04:43 AM
I wan´t to delete a palette from Autocad Tool Palette. How can I do?
thanks,
Ane
Hello Ane,
Sorry, There is no direct way to remove the tool palette.
The "ToolPaletteManager.Remove" method does not work and we have already logged this.
As a workaround, you may consider removing the catalog item from the .atc file since it is an XML file and can therefore be parsed / modified by your application but is not recommended.
ADN Support Specialist
Balaji_Ram
Message 2 of 4 (720 Views)
Re: Delete Palette from AutoCAD Tool Palette
12-11-2012 03:15 AM in reply to: _ane_
Hello Ane,
Balaji
Developer Technical Services
Autodesk Developer Network
khoa.ho
Message 3 of 4 (702 Views)
12-11-2012 07:53 AM in reply to: _ane_
ToolPaletteManager class was moved from acmgd.dll to AcTcMgd.dll in AutoCAD 2013 with some new classes and methods updated. But the API for tool palette is not comprehensive with many missing features. It should have some easy generic methods like Create(), Remove(), Load(), Unload() for tool palettes.
-Khoa
_ane_
Message 4 of 4 (401 Views)
01-09-2014 06:53 AM in reply to: Balaji_Ram
Sorry, always i forget to replay...
Thanks for replying, then I have to use another solution.
Ane
