.NET
Delete entites in Drawing
0 REPLIES 0
Message 1 of 1
Kamala
157 Views, 0 Replies
Hi all,
I'm trying to delete all the entites in the drawing.The following code actually takes a set of drawings opens all the drawings one by one and deletes the entites in each drawing.
The deletion of entities happens for single sheet,but dows not function for a set of drawing files.
Kindly suggest some solution
Try
For Each lCTempObjArr In larrMasterBOMlist
larrlistname = lCTempObjArr
lCActiveDoc = Application.DocumentManager.Open(larrlistname, True)
lCActiveDB = lCActiveDoc.Database
lCActiveTransMan = lCActiveDB.TransactionManager
lCActiveTrans = lCActiveTransMan.StartTransaction
lCLock = lCActiveDoc.LockDocument(DocumentLockMode.ProtectedAutoWrite, Nothing, Nothing, True)
lCActiveBlockTable = lCActiveTrans.GetObject(lCActiveDB.BlockTableId, OpenMode.ForWrite)
Dim btr As BlockTableRecord = CType(lCActiveTrans.GetObject(lCActiveBlockTable(btr.ModelSpace), OpenMode.ForWrite), BlockTableRecord)
For Each lCObjectId In btr
Dim Ent As Entity = CType(lCActiveTrans.GetObject(lCObjectId, OpenMode.ForWrite), Entity)
If TypeOf Ent Is BlockReference Then
Else
Ent.Erase()
Next
Next
lCActiveTrans.Commit()
lCLock.Dispose()
Thanks in advance
Kamala
0 REPLIES 0
”Boost
