.NET
Definition of Dynamic Blocks with .NET API
13 REPLIES 13
Message 1 of 14
4749 Views, 13 Replies
Hello, I'd like to know if it is possible, with the .NET API provided in AutoCAD 2009, to define dynamic blocks (dynamic properties and actions) completely from .NET code (VB.NET or C#).
If yes, can someone provide me a tutorial about this issue ?
Thank you.
13 REPLIES 13
Message 2 of 14
Unfortunately no, the authoring elements were not publicly
exposed.
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000
through 2009
href="http://www.acadxtabs.com">http://www.acadxtabs.com
from .NET code (VB.NET or C#). If yes, can someone provide me a tutorial about
this issue ? Thank you.
Message 3 of 14
Is it possible to show the dynamic properties?
I can retreive AttributeDefinitions, but no properties...
Message 4 of 14
sample code for iterating all dynamic blkrefs of MS and accessing their prop's:
using (BlockTable bt = (BlockTable)trans.GetObject(HostApplicationServices.WorkingDatabase.BlockTableId, OpenMode.ForRead, false))
BlockTableRecord btr = (BlockTableRecord)trans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForRead);
foreach(ObjectId objId in btr)
using (DBObject dbObj = trans.GetObject(objId, OpenMode.ForRead, false))
if (dbObj != null && dbObj.GetType() == typeof(BlockReference))
try
BlockReference br = dbObj as BlockReference;
if (br != null && br.IsDynamicBlock)
DynamicBlockReferencePropertyCollection dynBlkRefProps = br.DynamicBlockReferencePropertyCollection;
foreach (DynamicBlockReferenceProperty dynProp in dynBlkRefProps)
// ... access dynprop methods
// dynProp... PropertyName, Value, GetAllowedValues()
catch (System.Exception ex)
Message 5 of 14
Hi bobbydehero,
Thanks for your answer. However, this is not what I am looking for.
What you are describing, is how to get the PropertyREFERENCES from a BlockREFERENCE.
What I need to do is find the PropertyDEFINITIONS from a BlockDEFINITION.
I can extract the AttributeDefinitions from a blockDefinitions by iterating it's entities, but I still have not found how to extract the Properties...
Message 6 of 14
Ok, I'm not sure whether this suggestion works, before I've tried myself... but you might find something if you do this:
1) try querying the BlockTableRecord (that is dynamic) extension dictionary
2) get the "ACAD_ENHANCEDBLOCK" entry and examine the resbuf's - maybe you can find something there.
Message 7 of 14
Hi, thanks, I'll try that.
For now, we'll create a BlockReference in memory and access the Properties that way...
Message 8 of 14
Yeah, that's probably wise... I ran a quick test and found out that the ACAD_ENHANCEDBLOCK dictionary entry is an EvalGraph object that is not exposed in the .Net framework (Autodesk.AutoCAD.DatabaseServices.EvalGraph).
I then tried C++ and the corresponding AcDbEvalGraph class is accessible for 3rd party dev's, but the implementation of the node classes are still not public - meaning you can only access them as AcDbObjects, here's a printout of the class descriptor names (for my sample dynamic block table record):
AcDbBlockStretchAction
AcDbBlockMoveAction
AcDbBlockVisibilityParameter
AcDbBlockVisibilityGrip
AcDbBlockGripExpr
AcDbBlockGripExpr
AcDbBlockLookupParameter
AcDbBlockLookupAction
AcDbBlockLinearParameter
AcDbBlockLinearGrip
Message 9 of 14
bertvan -
It's actually possible to read the dynamic properties from a BlockTableRecord if you for some reason still want to...
Here's some sample code, and you'll need to reference the unsupported acmgdinternal module for it (generally not recommended):
Database db = HostApplicationServices.WorkingDatabase;
using (Transaction trans = db.TransactionManager.StartTransaction())
BlockTable bt = (BlockTable)(trans.GetObject(db.BlockTableId, OpenMode.ForRead));
if (bt.Has(sDynBlk) == true)
BlockTableRecord btr = (BlockTableRecord)trans.GetObject(bt[sDynBlk], OpenMode.ForRead);
if (btr.IsDynamicBlock)
try
DBDictionary extDictDynBT = (DBDictionary)trans.GetObject(btr.ExtensionDictionary, OpenMode.ForRead, false);
DBObject acadEnhancedBlk = (DBObject)trans.GetObject(extDictDynBT.GetAt("ACAD_ENHANCEDBLOCK"), OpenMode.ForRead, false);
EvalGraph graph = null;
ObjectId idGraph = acadEnhancedBlk.ObjectId;
if (!idGraph.IsNull)
graph = (EvalGraph)trans.GetObject(idGraph, OpenMode.ForRead);
if (graph != null)
int [] iNodes = graph.GetAllNodes();
foreach(int iNode in iNodes)
DBObject node = graph.GetNode((uint)iNode, OpenMode.ForRead, trans);
if (node != null)
EvalExpr eExpr = node as EvalExpr;
if (eExpr.GetType() == typeof(BlockLookupAction))
BlockLookupAction blua = eExpr as BlockLookupAction;
if (blua != null)
Array pDataTable;
LookupColumnDescriptorCollection descArray;
blua.GetLookupTable(out pDataTable, out descArray);
if (pDataTable != null)
if (eExpr.GetType() == typeof(BlockLookupParameter))
BlockLookupParameter blup = eExpr as BlockLookupParameter;
if (blup != null)
BlockParameterPropertyDescriptorCollection props = blup.PropertyDescription;
foreach (BlockParameterPropertyDescriptor prop in props)
Message 10 of 14
cean_au
just wondering if it can be done now?
Message 11 of 14
Hallex
in reply to: cean_au
I hope bobbydehero will not make a sense on me..
Try this slightly eedited code
{code}
        [CommandMethod("DynamicPropertiesTest","dyntest", CommandFlags.Modal )]
        public static void TestDynProps()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
                BlockReference bref = trans.GetObject(ed.GetEntity("\nSelect dynamic block").ObjectId, OpenMode.ForRead) as BlockReference;
                if (bref == null)
                    Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("Nothing or wrong object selected");
                    return;
                if (!bref.IsDynamicBlock)
                    Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("selected is not dynamick block");
                    return;
                BlockTableRecord btrec = trans.GetObject(bref.DynamicBlockTableRecord, OpenMode.ForRead,false) as BlockTableRecord;
                string sDynBlk = btrec.Name;
                        try
                            if (graph != null)
                                int[] iNodes = graph.GetAllNodes();
                                foreach (int iNode in iNodes)
                                    if (node != null)
                                            if (blua != null)
                                                Array pDataTable;
                                                    foreach (object obj in pDataTable)
                                                        ed.WriteMessage("\n\t{0}", obj.ToString());
                                            if (blup != null)
                                                Array pDataTable;
                                                    ed.WriteMessage("\n\t{0}", prop.PropertyName);
                                                    pDataTable = prop.ValueSetValues;
                                        if (eExpr.GetType() == typeof(BlockFlipParameter))
                                            BlockFlipParameter blup = eExpr as BlockFlipParameter;
                                            if (blup != null)
                                                Array pDataTable;
                                        //---------  add other actions / parameters same way here   -------------------//
                            Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.ToString());
{code}
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 12 of 14
cean_au
in reply to: Hallex
this still needs a dyna block first, not create one from scrath by program.
Message 13 of 14
Hallex
Do it yourself
I go out from there
Message 14 of 14
hermann.weiss
in reply to: Hallex
I would like to edit dynamic blocks with .Net. Unfortunately I do not find much on the internet. It seems as if Autodesk did not want to publish anything.
Can I learn more about this subject? Do you have a more recent example?
Or any other info?
Many thanks in advance
Hermann White
”Boost
