.NET
defining a Block from a 3dSolid at runtime
3 REPLIES 3
236 Views, 3 Replies
hi
could someone please tell me how i can make (define ) a block from a 3DSolid at runtime.
any help would be most appreciated
3 REPLIES 3
in other words, the program draws a box then it modifies it ( slices it, subtracts it ... ). After all this is done i want the program to turn it into a block.
You could do a search and find things like:
http://discussion.autodesk.com/forums/thread.jspa?messageID=5203915柋
HTH
Bill
What you should do is just create a new block and add the solid to
the block and slide and dice it there. The way you do that is not much
different from how you add a new object to the model space block,
except that you have to create the new block first.
The objects in model space reside in a block called Model_space.
So, rather than create and manipulate the solid in model space,
and then move it to a block, just create and manipulate the object
in a new block that you create first.
So, that reduces your question to how to add a new block to a
drawing. Searching this newsgroup should reveal some helpful
code.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6254607@discussion.autodesk.com...
into a block.
”Boost
