style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<jfboyer> wrote in messageThe
href="news:6199940@discussion.autodesk.com">news:6199940@discussion.autodesk.com...
command is 5rep: docA is the target database, it is where 5rep is entered docB
is the source database, and it's opened by 5rep 5rep is meant to copy objects
from docB to docA It requires a complex selection filter, that's why I need to
open docB to get an Editor. The following simplified code works when deep
cloning objects within the same database, i.e docB It fails when deep cloning
objects from docB to docA (see commented portion) Thanks for any help Jf
{code} [CommandMethod("5REP", CommandFlags.Session)] public void SynchREP() {
DocumentCollection docs = Application.DocumentManager; Document docA =
docs.MdiActiveDocument; Database dbA = docA.Database; Document docB =
docs.Open("docB.dwg"); Database dbB = docB.Database; DocumentLock dlockA =
docA.LockDocument(); Transaction trA =
dbA.TransactionManager.StartTransaction(); using (trA) { BlockTable btA =
(BlockTable)trA.GetObject( dbA.BlockTableId, OpenMode.ForRead );
BlockTableRecord msA = (BlockTableRecord)trA.GetObject(
btA[BlockTableRecord.ModelSpace], OpenMode.ForWrite ); DocumentLock dlockB =
docB.LockDocument(); Transaction trB =
dbB.TransactionManager.StartTransaction(); using (trB) { BlockTable btB =
(BlockTable)trB.GetObject( dbB.BlockTableId, OpenMode.ForRead );
BlockTableRecord msB = (BlockTableRecord)trB.GetObject(
btB[BlockTableRecord.ModelSpace], OpenMode.ForRead ); Editor edB =
docB.Editor; TypedValue[] tvsB = new TypedValue[] { new TypedValue( 67, "0" ),
new TypedValue( (int)DxfCode.Start, "INSERT" ) }; SelectionFilter sfB = new
SelectionFilter(tvsB); PromptSelectionResult psrB = edB.SelectAll(sfB);
SelectionSet ssetB = psrB.Value; ObjectId[] ena = ssetB.GetObjectIds();
ObjectIdCollection oicB = new ObjectIdCollection(ena); dbB.DeepCloneObjects(
oicB, msB.Id, /* <-- targets the same database */ new IdMapping(), /*
...and it works */ false); /* dbB.DeepCloneObjects( oicB, msA.Id, <--
targets another database new IdMapping(), ...and fails false); It raises an
exception: Autodesk.AutoCAD.Runtime.Exception: eWrongDatabase in
Autodesk.AutoCAD.DatabaseServices.Database.DeepCloneObjects */ trB.Commit(); }
trB.Dispose(); dlockB.Dispose(); } trA.Dispose(); dlockA.Dispose(); }
{code}
private void CloneObjectIds(ObjectIdCollection idsObjEntity, String strFileName)
try
Database dbNew = new Database(true, false);
Autodesk.AutoCAD.DatabaseServices.TransactionManager tm = dbNew.TransactionManager;
ObjectId idModelSpace;
using (Transaction mTy = tm.StartTransaction())
BlockTable bt = (BlockTable)tm.GetObject(dbNew.BlockTableId, OpenMode.ForRead, false);
BlockTableRecord Btr = (BlockTableRecord)tm.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForRead, false);
//idModelSpace = bt[BlockTableRecord.ModelSpace];
idModelSpace = Btr.Id;
IdMapping Mappin = new IdMapping();
RTA_ApplicationData.Db.WblockCloneObjects(idsObjEntity, idModelSpace, Mappin, DuplicateRecordCloning.Ignore, false);
String strFolderName = strFileName;
strFileName = strFileName + ".dwg";
String strPathName;
String pathName = Assembly.GetExecutingAssembly().Location;
pathName = pathName.Replace("LayerFilter.dll", "Drawing");
DirectoryInfo dirInfo = Directory.CreateDirectory(pathName + "\\" + strFolderName);
if (System.IO.File.Exists(pathName + "\\" + strFolderName))
return;
dbNew.SaveAs(pathName + "\\" + strFolderName + "\\" + strFileName, DwgVersion.Newest);
strPathName = pathName + "\\Temp\\" + strFileName;
here i take the objectid collection as xref filter by its layer name.i tried to clone the object in new dwg its shows eWrongdatabase.
If the document you are deep-cloning the objects into is not the Active document the graphics will not be correctly generated.
You can either make the destination document active, or don't open it in the editor (use Database.ReadDwgFile() to open it).
