.NET
DeepCloneObjects between two databases
4 REPLIES 4
2475 Views, 4 Replies
The command is 5rep:
docA is the target database, it is where 5rep is entered
docB is the source database, and it's opened by 5rep
5rep is meant to copy objects from docB to docA
It requires a complex selection filter, that's why I need to open docB to get an Editor.
The following simplified code works when deep cloning objects within the same database, i.e docB
It fails when deep cloning objects from docB to docA (see commented portion)
Thanks for any help
Jf
{code}
[CommandMethod("5REP", CommandFlags.Session)]
public void SynchREP()
DocumentCollection docs = Application.DocumentManager;
Document docA = docs.MdiActiveDocument;
Database dbA = docA.Database;
Document docB = docs.Open("docB.dwg");
Database dbB = docB.Database;
DocumentLock dlockA = docA.LockDocument();
Transaction trA = dbA.TransactionManager.StartTransaction();
using (trA)
BlockTable btA = (BlockTable)trA.GetObject(
dbA.BlockTableId,
OpenMode.ForRead
BlockTableRecord msA = (BlockTableRecord)trA.GetObject(
btA[BlockTableRecord.ModelSpace],
OpenMode.ForWrite
DocumentLock dlockB = docB.LockDocument();
Transaction trB = dbB.TransactionManager.StartTransaction();
using (trB)
BlockTable btB = (BlockTable)trB.GetObject(
dbB.BlockTableId,
OpenMode.ForRead
BlockTableRecord msB = (BlockTableRecord)trB.GetObject(
btB[BlockTableRecord.ModelSpace],
OpenMode.ForRead
Editor edB = docB.Editor;
TypedValue[] tvsB = new TypedValue[]
new TypedValue( 67, "0" ),
new TypedValue( (int)DxfCode.Start, "INSERT" )
SelectionFilter sfB = new SelectionFilter(tvsB);
PromptSelectionResult psrB = edB.SelectAll(sfB);
SelectionSet ssetB = psrB.Value;
ObjectId[] ena = ssetB.GetObjectIds();
ObjectIdCollection oicB = new ObjectIdCollection(ena);
dbB.DeepCloneObjects(
oicB,
msB.Id, /* <-- targets the same database */
new IdMapping(), /* ...and it works */
false);
oicB,
msA.Id, <-- targets another database
new IdMapping(), ...and fails
false);
It raises an exception:
Autodesk.AutoCAD.Runtime.Exception: eWrongDatabase
in Autodesk.AutoCAD.DatabaseServices.Database.DeepCloneObjects */
trB.Commit();
trB.Dispose();
dlockB.Dispose();
trA.Dispose();
dlockA.Dispose();
{code}
4 REPLIES 4
DeepClone (and deepCloneObjects) is only for
within the same database.  For cloning between databases, you must use the
wblockClone mechanism (in your case the wblockCloneObjects()
function).
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
The
command is 5rep: docA is the target database, it is where 5rep is entered docB
is the source database, and it's opened by 5rep 5rep is meant to copy objects
from docB to docA It requires a complex selection filter, that's why I need to
open docB to get an Editor. The following simplified code works when deep
cloning objects within the same database, i.e docB It fails when deep cloning
objects from docB to docA (see commented portion) Thanks for any help Jf
{code} [CommandMethod("5REP", CommandFlags.Session)] public void SynchREP() {
DocumentCollection docs = Application.DocumentManager; Document docA =
docs.MdiActiveDocument; Database dbA = docA.Database; Document docB =
docs.Open("docB.dwg"); Database dbB = docB.Database; DocumentLock dlockA =
docA.LockDocument(); Transaction trA =
dbA.TransactionManager.StartTransaction(); using (trA) { BlockTable btA =
(BlockTable)trA.GetObject( dbA.BlockTableId, OpenMode.ForRead );
btA[BlockTableRecord.ModelSpace], OpenMode.ForWrite ); DocumentLock dlockB =
docB.LockDocument(); Transaction trB =
dbB.TransactionManager.StartTransaction(); using (trB) { BlockTable btB =
(BlockTable)trB.GetObject( dbB.BlockTableId, OpenMode.ForRead );
btB[BlockTableRecord.ModelSpace], OpenMode.ForRead ); Editor edB =
docB.Editor; TypedValue[] tvsB = new TypedValue[] { new TypedValue( 67, "0" ),
new TypedValue( (int)DxfCode.Start, "INSERT" ) }; SelectionFilter sfB = new
SelectionFilter(tvsB); PromptSelectionResult psrB = edB.SelectAll(sfB);
SelectionSet ssetB = psrB.Value; ObjectId[] ena = ssetB.GetObjectIds();
ObjectIdCollection oicB = new ObjectIdCollection(ena); dbB.DeepCloneObjects(
oicB, msB.Id, /* <-- targets the same database */ new IdMapping(), /*
...and it works */ false); /* dbB.DeepCloneObjects( oicB, msA.Id, <--
targets another database new IdMapping(), ...and fails false); It raises an
exception: Autodesk.AutoCAD.Runtime.Exception: eWrongDatabase in
Autodesk.AutoCAD.DatabaseServices.Database.DeepCloneObjects */ trB.Commit(); }
trB.Dispose(); dlockB.Dispose(); } trA.Dispose(); dlockA.Dispose(); }
{code}
Thank you Art, it works:
{code}
dbB.WblockCloneObjects(
oicB,
msA.Id,
new IdMapping(),
DuplicateRecordCloning.Replace,
false);
{code}
AutoCAD NET C# copy from a drawing to another: use WblockClone
*edit*: the clone objects don't show up immediately in the target drawing window, although they are actually copied. I'm looking into QueueForGraphicsFlush to update the screen, not sure yet if this is the right way to do it.
Jf Edited by: jfboyer on Jun 12, 2009 12:54 PM
varadan01
                private void CloneObjectIds(ObjectIdCollection idsObjEntity, String strFileName)
            try
                Database dbNew = new Database(true, false);
                Autodesk.AutoCAD.DatabaseServices.TransactionManager tm = dbNew.TransactionManager;
                ObjectId idModelSpace;
                using (Transaction mTy = tm.StartTransaction())
                    BlockTable bt = (BlockTable)tm.GetObject(dbNew.BlockTableId, OpenMode.ForRead, false);
                    BlockTableRecord Btr = (BlockTableRecord)tm.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForRead, false);
                    //idModelSpace = bt[BlockTableRecord.ModelSpace];
                    idModelSpace = Btr.Id;
                IdMapping Mappin = new IdMapping();
                RTA_ApplicationData.Db.WblockCloneObjects(idsObjEntity, idModelSpace, Mappin, DuplicateRecordCloning.Ignore, false);
                String strFolderName = strFileName;
                strFileName = strFileName + ".dwg";
                String strPathName;
                String pathName = Assembly.GetExecutingAssembly().Location;
                pathName = pathName.Replace("LayerFilter.dll", "Drawing");
                DirectoryInfo dirInfo = Directory.CreateDirectory(pathName + "\\" + strFolderName);
                if (System.IO.File.Exists(pathName + "\\" + strFolderName))
                    return;
                dbNew.SaveAs(pathName + "\\" + strFolderName + "\\" + strFileName, DwgVersion.Newest);
                strPathName = pathName + "\\Temp\\" + strFileName;
here i take the objectid collection as xref filter by its layer name.i tried to clone the object in new dwg its shows eWrongdatabase.
With Regards,
GVaradarajan
DiningPhilosopher
If the document you are deep-cloning the objects into is not the Active document the graphics will not be correctly generated.
You can either make the destination document active, or don't open it in the editor (use Database.ReadDwgFile() to open it).
”Boost
