.NET
.NET
Distinguished Contributor
1 Kudo
Post 1 of 3
DeepCloneObjects and TransformBy with BlockReferences
236 Views, 2 Replies
02-14-2007 02:41 AM
I have a litte program which copies and rotates a
selectionset along a curve. It works without any problems for every object
except BlockReferences. If i do not transform the objects in
TransformSelectionSet2, also the BlockReferences are working, i just get the
error when i want to transform the BlockReferences. Does anyone know what i have
to do?
#region
Using directives
using
System;
using
System.Collections;
using
System.Collections.Generic;
using
Autodesk.AutoCAD.EditorInput;
using
Autodesk.AutoCAD.Geometry;
using
Autodesk.AutoCAD.DatabaseServices;
using
Autodesk.AutoCAD.GraphicsInterface;
using
Autodesk.AutoCAD.ApplicationServices;
using
Autodesk.AutoCAD.Runtime;
using
RSNNAcadApp.ExtendedCommands;
#endregion
[assembly:
CommandClass(typeof(RSNNAcadApp.ExtendedCommands.Copy))]
namespace
class Copy
private Matrix3d UcsMatrix;
private Point3d m_basePoint;
private Point3d m_destinationPoint;
private Curve BaseCurve;
private Matrix3d transMat;
private Vector3d xAxisFrom, yAxisFrom, zAxisFrom;
private Vector3d xAxisTo, yAxisTo, zAxisTo;
/// <summary>
/// Moves blockreferences along a Curve with a given distance
/// </summary>
CommandMethod("KOPIERENENTLANGMITBASIS", CommandFlags.UsePickSet)]
public void CopyAlongCurve()
Database db = HostApplicationServices.WorkingDatabase;
//Transaction myT = db.TransactionManager.StartTransaction();
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
try
PromptSelectionOptions ssOptions = new PromptSelectionOptions();
ssOptions.MessageForAdding =
"\nObjekte wählen: ";
ssOptions.MessageForRemoval =
"\nObjekte entfernen: ";
ssOptions.AllowDuplicates =
true;
PromptSelectionResult ssResult = ed.GetSelection(ssOptions);
if (ssResult.Status != PromptStatus.OK)
return;
if (ssResult.Value.Count == 0)
return;
PromptEntityOptions entOptions = new PromptEntityOptions("\nBezugslinie wählen, entlang der kopiert werden soll");
entOptions.SetRejectMessage(
"\nNur Kurven können gewählt werden.");
entOptions.AddAllowedClass(
typeof(Curve), false);
PromptEntityResult entResult = ed.GetEntity(entOptions);
if (entResult.Status != PromptStatus.OK)
return;
ObjectId BaseCurveId = entResult.ObjectId;
//Get a base point from the user
PromptPointResult pointResult = ed.GetPoint("\nBasispunkt: ");
if (pointResult.Status != PromptStatus.OK)
return;
UcsMatrix = ed.CurrentUserCoordinateSystem;
m_basePoint = pointResult.Value.TransformBy(UcsMatrix);
do
using (Transaction myT = db.TransactionManager.StartTransaction())
BaseCurve = (
Curve)myT.GetObject(BaseCurveId, OpenMode.ForRead);
if (BaseCurve == null)
return;
Point3d tmpbasePoint = BaseCurve.GetClosestPointTo(m_basePoint, false);
xAxisFrom = BaseCurve.GetFirstDerivative(tmpbasePoint).GetNormal();
yAxisFrom = BaseCurve.GetSecondDerivative(tmpbasePoint).GetNormal();
if (yAxisFrom.IsZeroLength() || !yAxisFrom.IsPerpendicularTo(xAxisFrom))
if (BaseCurve.IsPlanar)
yAxisFrom = BaseCurve.GetPlane().Normal.CrossProduct(xAxisFrom.GetNormal()).GetNormal();
else
yAxisFrom = xAxisFrom.GetPerpendicularVector().GetNormal();
zAxisFrom = xAxisFrom.CrossProduct(yAxisFrom).GetNormal();
//Initiate the drag callback delegate
DragCallback dragCallbackDelegate = this.FollowCursor;
//Start the drag operation
PromptDragOptions dragOptions = new PromptDragOptions(ssResult.Value, "\nZweiter Punkt angeben oder", dragCallbackDelegate);
string kwDefault = "Beenden";
dragOptions.Keywords.Add(kwDefault);
dragOptions.Keywords.Default = kwDefault;
PromptPointResult destinationPointResult = ed.Drag(dragOptions);
if (destinationPointResult.Status != PromptStatus.OK)
return;
m_destinationPoint = destinationPointResult.Value.TransformBy(UcsMatrix);
//m_destinationPoint = destinationPointResult.Value;
Point3d tmpdestinationPoint = BaseCurve.GetClosestPointTo(m_destinationPoint, false);
xAxisTo = BaseCurve.GetFirstDerivative(tmpdestinationPoint).GetNormal();
yAxisTo = BaseCurve.GetSecondDerivative(tmpdestinationPoint).GetNormal();
if (yAxisTo.IsZeroLength() || !yAxisTo.IsPerpendicularTo(xAxisTo))
yAxisTo = BaseCurve.GetPlane().Normal.CrossProduct(xAxisTo.GetNormal()).GetNormal();
else
yAxisTo = xAxisTo.GetPerpendicularVector().GetNormal();
zAxisTo = xAxisTo.CrossProduct(yAxisTo).GetNormal();
//Determine the final displacement matrix
transMat =
Matrix3d.AlignCoordinateSystem(
m_basePoint, xAxisFrom, yAxisFrom, zAxisFrom,
m_destinationPoint, xAxisTo, yAxisTo, zAxisTo);
myT.Commit();
//transform the ss to the new location
this.TransformSelectionSet2(ssResult.Value, transMat);
while (true);
finally
//myT.Dispose();
//DragCallback Delegate
public SamplerStatus FollowCursor(Point3d currentPoint, ref Matrix3d transMat)
Point3d tmpcurrentPoint = BaseCurve.GetClosestPointTo(currentPoint.TransformBy(UcsMatrix), false);
xAxisTo = BaseCurve.GetFirstDerivative(tmpcurrentPoint).GetNormal();
yAxisTo = BaseCurve.GetSecondDerivative(tmpcurrentPoint).GetNormal();
else
transMat =
currentPoint.TransformBy(UcsMatrix), xAxisTo, yAxisTo, zAxisTo);
return SamplerStatus.OK;
private void TransformSelectionSet(SelectionSet ss, Matrix3d transMat)
if (ss.Count == 0)
return;
Database targetDatabase = ss[0].ObjectId.Database;
using (Transaction trans = targetDatabase.TransactionManager.StartTransaction())
BlockTableRecord currentSpace = (BlockTableRecord)trans.GetObject(targetDatabase.CurrentSpaceId, OpenMode.ForWrite);
foreach (SelectedObject selectedObj in ss)
Entity selectedEntity = (Entity)trans.GetObject(selectedObj.ObjectId, OpenMode.ForRead);
Entity transformedEntity = selectedEntity.GetTransformedCopy(transMat);
currentSpace.AppendEntity(transformedEntity);
trans.AddNewlyCreatedDBObject(transformedEntity,
true);
trans.Commit();
private void TransformSelectionSet2(SelectionSet ss, Matrix3d transMatrix)
if (ss.Count == 0)
return;
ObjectIdCollection entityCollection = new ObjectIdCollection(ss.GetObjectIds());
IdMapping idMap = new IdMapping();
targetDatabase.DeepCloneObjects(entityCollection, targetDatabase.CurrentSpaceId, idMap,
false);
foreach (IdPair pair in idMap)
Entity clonedEntity = (Entity)trans.GetObject(pair.Value, OpenMode.ForWrite);
clonedEntity.TransformBy(transMatrix);
trans.Commit();
*Tony Tanzillo
Post 2 of 3
Re: DeepCloneObjects and TransformBy with BlockReferences
02-14-2007 08:58 AM in reply to: RolandF
Autodesk has worked very hard to make it nearly impossible
to post readable code in their discussion forums.
Because of that, its hard for me to look at your code, so I'll
ask you to post it as an attachment (*.cs or in a .zip file).
Also, you don't mention what error message you're getting.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5485952@discussion.autodesk.com...
I have a litte program which copies and rotates a selectionset along a curve. It works without any problems for every object except BlockReferences. If i do not transform the objects in TransformSelectionSet2, also the BlockReferences are working, i just get the error when i want to transform the BlockReferences. Does anyone know what i have to do?
#region Using directivesusing System;using System.Collections;using System.Collections.Generic;using Autodesk.AutoCAD.EditorInput;using Autodesk.AutoCAD.Geometry;using Autodesk.AutoCAD.DatabaseServices;using Autodesk.AutoCAD.GraphicsInterface;using Autodesk.AutoCAD.ApplicationServices;using Autodesk.AutoCAD.Runtime;using RSNNAcadApp.ExtendedCommands;#endregion[assembly: CommandClass(typeof(RSNNAcadApp.ExtendedCommands.Copy))]namespace RSNNAcadApp.ExtendedCommands{class Copy{private Matrix3d UcsMatrix;private Point3d m_basePoint;private Point3d m_destinationPoint;private Curve BaseCurve;private Matrix3d transMat;private Vector3d xAxisFrom, yAxisFrom, zAxisFrom;private Vector3d xAxisTo, yAxisTo, zAxisTo;/// /// Moves blockreferences along a Curve with a given distance/// [CommandMethod("KOPIERENENTLANGMITBASIS", CommandFlags.UsePickSet)]public void CopyAlongCurve(){Database db = HostApplicationServices.WorkingDatabase;//Transaction myT = db.TransactionManager.StartTransaction();Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;try{PromptSelectionOptions ssOptions = new PromptSelectionOptions();ssOptions.MessageForAdding = "\nObjekte wählen: ";ssOptions.MessageForRemoval = "\nObjekte entfernen: ";ssOptions.AllowDuplicates = true; PromptSelectionResult ssResult = ed.GetSelection(ssOptions);if (ssResult.Status != PromptStatus.OK)return;if (ssResult.Value.Count == 0)return;PromptEntityOptions entOptions = new PromptEntityOptions("\nBezugslinie wählen, entlang der kopiert werden soll");entOptions.SetRejectMessage("\nNur Kurven können gewählt werden.");entOptions.AddAllowedClass(typeof(Curve), false);PromptEntityResult entResult = ed.GetEntity(entOptions);if (entResult.Status != PromptStatus.OK)return;ObjectId BaseCurveId = entResult.ObjectId;//Get a base point from the userPromptPointResult pointResult = ed.GetPoint("\nBasispunkt: ");if (pointResult.Status != PromptStatus.OK)return;UcsMatrix = ed.CurrentUserCoordinateSystem;m_basePoint = pointResult.Value.TransformBy(UcsMatrix);do{using (Transaction myT = db.TransactionManager.StartTransaction()){BaseCurve = (Curve)myT.GetObject(BaseCurveId, OpenMode.ForRead);if (BaseCurve == null)return;Point3d tmpbasePoint = BaseCurve.GetClosestPointTo(m_basePoint, false);xAxisFrom = BaseCurve.GetFirstDerivative(tmpbasePoint).GetNormal();yAxisFrom = BaseCurve.GetSecondDerivative(tmpbasePoint).GetNormal();if (yAxisFrom.IsZeroLength() || !yAxisFrom.IsPerpendicularTo(xAxisFrom)){if (BaseCurve.IsPlanar)yAxisFrom = BaseCurve.GetPlane().Normal.CrossProduct(xAxisFrom.GetNormal()).GetNormal();elseyAxisFrom = xAxisFrom.GetPerpendicularVector().GetNormal();}zAxisFrom = xAxisFrom.CrossProduct(yAxisFrom).GetNormal();//Initiate the drag callback delegateDragCallback dragCallbackDelegate = this.FollowCursor;//Start the drag operationPromptDragOptions dragOptions = new PromptDragOptions(ssResult.Value, "\nZweiter Punkt angeben oder", dragCallbackDelegate);string kwDefault = "Beenden";dragOptions.Keywords.Add(kwDefault);dragOptions.Keywords.Default = kwDefault;PromptPointResult destinationPointResult = ed.Drag(dragOptions);if (destinationPointResult.Status != PromptStatus.OK)return;m_destinationPoint = destinationPointResult.Value.TransformBy(UcsMatrix);//m_destinationPoint = destinationPointResult.Value;Point3d tmpdestinationPoint = BaseCurve.GetClosestPointTo(m_destinationPoint, false);xAxisTo = BaseCurve.GetFirstDerivative(tmpdestinationPoint).GetNormal();yAxisTo = BaseCurve.GetSecondDerivative(tmpdestinationPoint).GetNormal();if (yAxisTo.IsZeroLength() || !yAxisTo.IsPerpendicularTo(xAxisTo)){if (BaseCurve.IsPlanar)yAxisTo = BaseCurve.GetPlane().Normal.CrossProduct(xAxisTo.GetNormal()).GetNormal();elseyAxisTo = xAxisTo.GetPerpendicularVector().GetNormal();}zAxisTo = xAxisTo.CrossProduct(yAxisTo).GetNormal();//Determine the final displacement matrixtransMat = Matrix3d.AlignCoordinateSystem(m_basePoint, xAxisFrom, yAxisFrom, zAxisFrom,m_destinationPoint, xAxisTo, yAxisTo, zAxisTo);myT.Commit();}//transform the ss to the new locationthis.TransformSelectionSet2(ssResult.Value, transMat);} while (true);}finally{//myT.Dispose();}}//DragCallback Delegatepublic SamplerStatus FollowCursor(Point3d currentPoint, ref Matrix3d transMat){Point3d tmpcurrentPoint = BaseCurve.GetClosestPointTo(currentPoint.TransformBy(UcsMatrix), false);xAxisTo = BaseCurve.GetFirstDerivative(tmpcurrentPoint).GetNormal();yAxisTo = BaseCurve.GetSecondDerivative(tmpcurrentPoint).GetNormal();if (yAxisTo.IsZeroLength() || !yAxisTo.IsPerpendicularTo(xAxisTo)){if (BaseCurve.IsPlanar)yAxisTo = BaseCurve.GetPlane().Normal.CrossProduct(xAxisTo.GetNormal()).GetNormal();elseyAxisTo = xAxisTo.GetPerpendicularVector().GetNormal();}zAxisTo = xAxisTo.CrossProduct(yAxisTo).GetNormal();//Determine the final displacement matrixtransMat = Matrix3d.AlignCoordinateSystem(m_basePoint, xAxisFrom, yAxisFrom, zAxisFrom,currentPoint.TransformBy(UcsMatrix), xAxisTo, yAxisTo, zAxisTo);return SamplerStatus.OK;} private void TransformSelectionSet(SelectionSet ss, Matrix3d transMat){if (ss.Count == 0){return;}Database targetDatabase = ss[0].ObjectId.Database;using (Transaction trans = targetDatabase.TransactionManager.StartTransaction()){BlockTableRecord currentSpace = (BlockTableRecord)trans.GetObject(targetDatabase.CurrentSpaceId, OpenMode.ForWrite);foreach (SelectedObject selectedObj in ss){Entity selectedEntity = (Entity)trans.GetObject(selectedObj.ObjectId, OpenMode.ForRead);Entity transformedEntity = selectedEntity.GetTransformedCopy(transMat);currentSpace.AppendEntity(transformedEntity);trans.AddNewlyCreatedDBObject(transformedEntity, true);}trans.Commit();}}private void TransformSelectionSet2(SelectionSet ss, Matrix3d transMatrix){if (ss.Count == 0)return;Database targetDatabase = ss[0].ObjectId.Database;using (Transaction trans = targetDatabase.TransactionManager.StartTransaction()){ObjectIdCollection entityCollection = new ObjectIdCollection(ss.GetObjectIds());IdMapping idMap = new IdMapping();targetDatabase.DeepCloneObjects(entityCollection, targetDatabase.CurrentSpaceId, idMap, false);foreach (IdPair pair in idMap){Entity clonedEntity = (Entity)trans.GetObject(pair.Value, OpenMode.ForWrite);clonedEntity.TransformBy(transMatrix);}trans.Commit();}} }}
1 Kudo
Post 3 of 3
02-14-2007 11:19 AM in reply to: RolandF
Thank you, Tony.
Attached you can find the code and here is the error message. I get this
message only when i have blocks in my ss.
System.Reflection.TargetInvocationException: Ein Aufrufziel hat einen
Ausnahmefehler verursacht. ---> Autodesk.AutoCAD.Runtime.Exception:
eNotApplicable
bei Autodesk.AutoCAD.DatabaseServices.Entity.TransformBy(Matrix3d
transform)
bei RSNNAcadApp.ExtendedCommands.Copy.TransformSelectionSet2(SelectionSet
bei RSNNAcadApp.ExtendedCommands.Copy.CopyAlongCurve()
--- Ende der internen Ausnahmestapelüberwachung ---
bei System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[]
arguments, SignatureStruct& sig, MethodAttributes methodAttributes,
RuntimeTypeHandle typeOwner)
bei System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[]
arguments, Signature sig, MethodAttributes methodAttributes,
bei System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags
invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean
skipVisibilityChecks)
invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
