.NET
DeepClone BlockReference
5 REPLIES 5
1097 Views, 5 Replies
I want to make a copy of
some BlockReferences, they can be dynamic therefor I have to use
DeepClone. When I try it with something like the following code nothing
happens. I think the problem is the currSpace. What should be instead for the
ownerPointer?
{code}
DBObject
tmpOriginalEntity = (
Entity
size=2>)myT.GetObject(objId,
size=2>OpenMode
.ForWrite);
BlockReference
tmpOriginalBlock = tmpOriginalEntity
size=2>as
size=2>BlockReference
if (tmpOriginalBlock !=
null)
    IdMapping
size=2> idMap =
new
IdMapping
size=2>();
    DBObject
size=2> currSpace = (
DBObject
size=2>)myT.GetObject(db.CurrentSpaceId,
size=2>OpenMode
.ForWrite);
    DBObject
size=2> tmpnewBlockRef = tmpOriginalBlock.DeepClone(currSpace, idMap,
false);
{code}
5 REPLIES 5
Roland_Feletic
Again without formating:
DBObject tmpOriginalEntity = (Entity)myT.GetObject(objId, OpenMode.ForWrite);
BlockReference tmpOriginalBlock = tmpOriginalEntity as BlockReference;
if (tmpOriginalBlock != null)
IdMapping idMap = new IdMapping();
DBObject currSpace = (DBObject)myT.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
DBObject tmpnewBlockRef = tmpOriginalBlock.DeepClone(currSpace, idMap, false);
} Edited by: feletic@pauser.at on Nov 18, 2008 5:29 PM
You dont call DeepClone on a DBObject, you call
the
DeepCloneObjects method of the Database.
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000
through 2009
href="http://www.acadxtabs.com">http://www.acadxtabs.com
"Roland Feletic" <feletic_at_pauser_dot_at> wrote in message
href="news:6074184@discussion.autodesk.com">news:6074184@discussion.autodesk.com
use DeepClone. When I try it with something like the following code
nothing happens. I think the problem is the currSpace. What should be instead
for the ownerPointer?
{code}
DBObject
Entity
size=2>OpenMode
.ForWrite);
BlockReference
size=2>as
size=2>
null)
    IdMapping
size=2> idMap =
new
IdMapping
size=2>();
    DBObject
DBObject
size=2>OpenMode
.ForWrite);
    DBObject
false);
size=2>{code}
Thank you, Tony.
Now I did it like the following code and it works.
But may I ask you one question. When do I use DeepClone?
IdMapping
size=2> idMap =
new
IdMapping
face=Arial>();
size=2>ObjectIdCollection
entityCollection =
color=#0000ff size=2>new
face=Arial>();
entityCollection.Add(objId);
db.DeepCloneObjects(entityCollection, db.CurrentSpaceId,
idMap,
size=2>false
the
through 2009
instead for the ownerPointer?
{code}
DBObject
Entity
size=2>OpenMode
.ForWrite);
BlockReference
size=2>as
size=2>
if
null
size=2>)
IdMapping
idMap =
size=2>new
size=2>IdMapping
    DBObject
DBObject
size=2>OpenMode
.ForWrite);
    DBObject
false);
size=2>{code}
You don't use DeepClone().
The DeepCloneObjects() method calls it (or its native
counterpart)
as part of the cloning process.
through 2009
href="news:6074895@discussion.autodesk.com">news:6074895@discussion.autodesk.com
Thank you, Tony.
works. But may I ask you one question. When do I use DeepClone?
IdMapping
size=2> idMap =
new
IdMapping
face=Arial>();
entityCollection =
face=Arial>();
idMap,
size=2>false
the
Supporting AutoCAD
2000 through 2009
have to use DeepClone. When I try it with something like the
following code nothing happens. I think the problem is the currSpace. What
should be instead for the ownerPointer?
{code}
DBObject
Entity
size=2>OpenMode
.ForWrite);
BlockReference
size=2>as
size=2>
if
null
size=2>)
IdMapping
idMap =
size=2>new
size=2>IdMapping
DBObject
currSpace = (
size=2>DBObject
OpenMode
size=2>.ForWrite);
DBObject
tmpnewBlockRef =
size=2>false
size=2>{code}
Thank you.
counterpart)
through 2009
Thank you, Tony.
IdMapping
size=2> idMap =
new
IdMapping
face=Arial>();
entityCollection =
new
color=#2b91af size=2>ObjectIdCollection
face=Arial>();
idMap,
size=2>false
the
Supporting AutoCAD
2000 through 2009
What should be instead for the ownerPointer?
{code}
DBObject
size=2>Entity
color=#2b91af size=2>OpenMode
.ForWrite);
BlockReference
size=2>as
size=2>
if
null
size=2>)
IdMapping
idMap =
size=2>new
size=2>IdMapping
DBObject
currSpace = (
size=2>DBObject
OpenMode
size=2>.ForWrite);
DBObject
tmpnewBlockRef =
size=2>false
size=2>{code}
”Boost
