Show only
Search instead for
C#2005Express is Significantly different to C#2003 < with which I have no
problems debugging>
[quote]
A project with an Output Type of Class Library cannot be started directly.
In order to debug this project, add an executable project to this solution
which references the library project.
Set the executable project as the startup project.
[/quote]
.. which is double dutch to me ..
Regards
Kerry
//////////////////// wrote in message news:4917751@discussion.autodesk.com...
Im assuming it doesn't setup the same way as 2003?
