I am used VBA/VB6 so using COM interop helps me for now until they dump it which I heard was the plan?
Is there a way to debug .net apps live as I did with VBA?
Seems to work with instructions but not for requests.
For example .net doesn't know to pause when I request a input from AutoCAD. eg.
sset.Select(5, , , , )
Building a dll, loading it into AutoCAD then not quite knowing what is going on is painful and very time consuming.
If you start the application from within visual studio you can debug line by line. You just need to set the startup application to acad.exe and netload the command from the copy that loads.
I don't believe they are discontinuing autocad.interop that would be a bit catastropic.
They are discontinuing VBA (I'm told) in 2012. Altho that may change.
Thanks for your reply!
I have a few apps written and compiled in VB6 dlls. Will they survive any change by Autodesk?
I guess my gripe with .Net is waiting for a new instance of AutoCAD then NETLOADing the app.
Almost makes me want to build it in VBA then convert it to .Net.
Just realized that I can debug sent commands directly to the active instance from Visual Studio without the dll and temporarily generate responces to requests.
It’s only drawing requests that need the dll to be created.
Makes things quicker.
// Called Kerry in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>; another Swamper
VBA to VB.Net just needs a few adjustments so copy and paste. No need anymore though.
It's just the debugging of requests needs building the dll, netloading it and running the command and a process I could do without.
@sgrya1 wrote:Just realized that I can debug sent commands directly to the active instance from Visual Studio without the dll and temporarily generate responces to requests.
Can you explain what you mean and how you are sending commands?
I’ve just realised that I only need to build the debug dll once and not each time I want to debug.
I call commands using the CommandMethod
I can edit in debug mode but occasionally get fatal exceptions or more often the code just needs to be stopped and restarted. In which case the debug instance of AutoCAD is closed and needs to be restarted when I press play. I just seem to spend a lot of time waiting for AutoCAD to load and Netloading.
If I disable Acad.exe as the start up debug app then all sent commands go straight to the active instance so I can easily and quickly debug these.
It’s just the drawing requests that need Acad.exe set as the startup debug application.
Seems I've been playing with the same project under different environments.
One is a Windows Forms Application which sends commands straight to the currently active instance of AutoCAD
The other a Class Library. Does the same thing but needs a new instance of AutoCAD and Netloading the dll.
Good thing is that I can flick from one type to the other by changing the app type, startup object and debug mode.
Windows Form App can start off a blank form kicking off a subroutine.
Sorry for the confusion.
