.NET
Valued Contributor
KevinMacDonald
Message 1 of 6 (3,407 Views)
Debugging .NET: Autocad 2013 with Visual Studio 2012
3407 Views, 5 Replies
12-15-2012 03:59 PM
As the title of the question indicates I am using Autocad 2013 and Visual Studio 2012. I have installed the ObjectARX 2013 SDK and have built one of the .NET samples - Prompts.csproj for example - and have successfully installed the DLL using NETLOAD. The only problem is that I cannot debug. If I use Visual Studio to attach to the acad.exe process both Autocad and Visual Studio will freeze as soon as I run one of the Prompts.cs commands and attempt to hit a breakpoint.
Visual Studio project settings of interest:
- platform target is Any CPU (I have tried all the options. Same problem)
- Target framework is .NET Framework 4.5
- Referenced DLLs are set to Copy Local = True (I have tried both True and False. Same problem).
Between not being able to reload a .NET DLL without restarting Autocad (because of the well known lack of a NETUNLOAD function), and not being able to debug into my code this is a very challenging development environment. I am blind with both hands tied behind my back. Any suggestions are most appreciated.
Inventor 2013
I never use the "attach to existing process", I have my project settings defined to start AutoCAD when I click onto "start" in my project.
Has to be 4.0
Has to be set to false
Good luck, - alfred -
Alfred.NESWADBA
Message 2 of 6 (3,401 Views)
Re: Debugging .NET: Autocad 2013 with Visual Studio 2012
12-15-2012 04:08 PM in reply to: KevinMacDonald
Has to be 4.0
Alfred NESWADBA
Valued Contributor
KevinMacDonald
Message 3 of 6 (3,375 Views)
12-16-2012 02:41 AM in reply to: Alfred.NESWADBA
I'll be damned! That worked. Thanks Alfred. Framework 4 instead of 4.5. Who knew?
FYI In case anyone else is trying to set up an effective development environment there's a nifty little NetReload utility out there that allows one to make rapid code changes and reload your assembly on the fly via a clever workaround to the AppDomain problem. You can't line debug that way, but if you need to quickly try new things and don't want to burn the time to constantly restart Autocad it's pretry neat.
Inventor 2013
Valued Contributor
tanerpro
Message 4 of 6 (2,681 Views)
04-30-2013 01:33 AM in reply to: KevinMacDonald
I am doing exactly the sam thing, everything works fine for me, I can step into (F8) but the problem is I can't see what is happening in AutoCAD step by step because it can't be activated or refreshed durind debug. At the end of the run AutoCAD activates and I see the whole process. I want to see step by step what happens each line of code execute. How to do this?
Best Regards
VS2012
Autocad 2012
Windows 7 (x64)
AutoCAD 2012 (x64)
Active Member
m.yenafaradam
Message 5 of 6 (1,762 Views)
Re: Debugging .NET: Autocad 2014 with Visual Studio 2012
09-13-2013 07:05 AM in reply to: tanerpro
I was debugging my ObjectARX application, then I saw VS and ACAD crash when I want to attach VS debuger to acad , I could not find any solution just might someone else  have the same problem I am reporting my case.
After 12 hours struggling with VS and Autocade chekcing all the possible solution I found that when you debug a project that targets accoreconsole (accoreconsole dll is refrenced) in acad you can not debug when you want debug it both VS and ACad crash!!
(By the way I tried to use ACAD in place of accorconsole to debug my dll beacuse ACAD reports loading failuire  in netload command but accoreconsole does not report it. One offer to ObjectARX team, it would be nice in the case of failure in loading .net dll acccorecosnsle like ACad ireports exception (the reason that load was not sucessful like security reason or etc)
Br,
Valued Mentor
fieldguy
Message 6 of 6 (1,750 Views)
09-13-2013 08:29 AM in reply to: tanerpro
Use 2 monitors
