you may need to edit acad.exe.config and uncomment the .net runtime version,
as the default setting is to use the latest version of the .net runtime.
This is what I had to do to get debuging to work even though acad run fine
for editing drawings.
Regards
Mark
I fould that I had to do this to debug a .net dll even though acad fine
under normal use.
"Bill Hashman" wrote in message
news:5072640@discussion.autodesk.com...
See comments here:
http://www.manusoft.com/Resources/ARXTips/Index.stm
"Zhongwei Xia" wrote in message
news:5049108@discussion.autodesk.com...
It's working now after I modified AutoCAD 2006 acad.exe.config file.
Let it still use .net framework version 1.1.4322. Otherwise, it always use
the latest version of the framework installed on computer.
news:5049102@discussion.autodesk.com...
I'm using Visual Studio C# .net 2003 version to create AutoCad 2006 ARX
application. After I installed Visual Studio 2005, ARX debugging stop
working - AutoCAD is started and closed automatically after starting
debugging.
Please help. Thanks.
