I'm not sure this is Autocad specific, but I haven't been able to find anything on the issue anywhere else.
I use this Dictionary <string, Dictionary<string, int>> to gather data from several dwg files.
The program works Ok but when I try to expand the dictionary in the VS 2008 debugger it (the debugger) invariably crashes
(after a few seconds) and Autocad exits with 'Recursion too deep; the stack overflowed' error.
The dictionary is very small, typically a few dozens of items.
Has anyone seen this before?
Thanks for your help,
alex
Your going to have to post some code, or explain what you are trying to accomplish.
This is not enough information.
HI fieldguy,
As I said, the crash occurs only when the debugger tries to open the dictionary.
The program works fine. I can access the dictionary, iterate through it, etc.
I just can't open it in the visualizer.
And due to its small size, how can it cause a stack overflow?
alex
Have you tried a dump file? http://msdn.microsoft.com/en-us/library/d5zhxt22(v=vs.90).aspx
If you post some code, someone can try it for confirmation. In your 1st message, you said the debugger crashes and Autocad exits - generating the "Recursion too deep - stack overflowed error". It should be easy to re-create.
Are you using readdwg, or are the dwg files open in the editor?
Hi fieldguy,
Sorry, my bad. Something you wrote got me looking harder and surely there was a bug in the dictionary-derived class accessors, which indeed led to an infinite loop when the debugger tried to look inside the object (at least I think this is the answer, although I don't know what the debugger does exactly).
If it is of interest I could post the [bad] code.
What blinded me was the fact that the program used the class w/o any problem, it was only when the debugger looked, so I blamed the innocent debugger.
Apologies and thanks again,
alex
I'm glad you figured it out. Your post caught my eye because I do a lot of sql - linq - datatable - datagridview stuff and use multi dimension dictionaries regularly (best thing since cheese buns).
