.NET
Amremad
Message 1 of 9 (1,286 Views)
Debugger Breakpoints Doesn't Work
1286 Views, 8 Replies
04-01-2013 02:49 AM
iam using CAD2010 & VS2012
start external program done and no problem with attact to process
i set breakPoints in my program then i loaded it to autocad using netload so this breakpoint doesn't work , and my program complete all code without stop at my breakpoint .
any solution ??
Alfred.NESWADBA
Message 2 of 9 (1,271 Views)
Re: Debugger Breakpoints Doesn't Work
04-01-2013 03:53 AM in reply to: Amremad
when you added your references to acdbmgd.dll and acmgd.dll have you set the property "copy local" to false? By default when you create the reference VS set this to TRUE and that should not be.
Another option for not stopping at breakpoints is that your VS-project is set to anohter Framework than AutoCAD is using. Look >>>here<<< to see what AutoCAD release needs what Framework release (without doing some tricks like modifying the acad.exe.config)
Good luck, - alfred -
Alfred NESWADBA
Amremad
Message 3 of 9 (1,271 Views)
04-01-2013 03:58 AM in reply to: Alfred.NESWADBA
it's already done before i ask
Alfred.NESWADBA
Message 4 of 9 (1,256 Views)
04-01-2013 06:25 AM in reply to: Amremad
if you take any of the samples from the ObjectARX-kit, do you have the same problem with any of these projects?
- alfred -
Alfred NESWADBA
Amremad
Message 5 of 9 (1,251 Views)
04-01-2013 06:43 AM in reply to: Amremad
i din't try another ,
i will try with cad 2014 later and tell you what's happen
_gile
Message 6 of 9 (1,241 Views)
04-01-2013 07:58 AM in reply to: Amremad
By my side, to avoid debugging problems, I use VS2012 when targeting A2012 or newer and VS2010 for prior versions.
Gilles Chanteau
norman.yuan
Message 7 of 9 (1,236 Views)
04-01-2013 09:25 AM in reply to: Amremad
You probably need to set undocumented system variable Fiberworld from 1 to 0 with command "NEXTFIBERWORLD" and bear the consequence (of ribbon/menu/toolbar stop working).
Searching this forum and/or AutoCAD DevBlog and/or Kean's blog  for "Fiberworld" would bring you some more information on this issue.
Active Member
vinkd
Message 8 of 9 (1,195 Views)
04-03-2013 07:44 AM in reply to: Amremad
I've had this issue with AutoCAD and Visual Studio 2010. In my case, neither of the aforementioned fixes helped, and I ended up editing acad.exe.config to use runtime 2.0:
<configuration>
  <startup>
    <supportedRuntime version="v2.0.50727" />
  </startup>
</configuration>
This enabled debugging, and everything else seems to work just fine. Hope I'm not a moron for posting a VS2010 fix :')
Amremad
Message 9 of 9 (1,184 Views)
04-03-2013 10:12 AM in reply to: Amremad
i tried another version of autocad , iam currently working by CAD2010 and converting to CAD2014
so it's work good with CAD2014 and no problem with breakpoint
so i think auto2010 not supported for breakpoint (maybe)
