.NET
.NET
Alfred.NESWADBA
Message 11 of 18 (253 Views)
Re: Debug using Visual Studio Express 2013 and AutoCad 2010/2014
03-20-2014 09:30 AM in reply to: wbdehaan
may I come back to  that question from post 4 in this thread?
>> What happens if you set a breakpoint at the line where you calling the MsgBox and start then the command?
Does it stop or does it ignore the breakpoint?
- alfred -
Alfred NESWADBA
Valued Contributor
wbdehaan
Message 12 of 18 (242 Views)
03-20-2014 11:40 PM in reply to: Alfred.NESWADBA
Hi Alfred,
it ignores the breakpoint completely.
f.y.i.: It starts the correct (debug)-dll, because when I stop the running project and change the text in the messagebox and rerun the netload command in AutoCad, it shows the change in text, therefore i'm sure it's not loading a different dll.
kind regards, Wouter
Alfred.NESWADBA
Message 13 of 18 (219 Views)
03-23-2014 07:23 AM in reply to: wbdehaan
I'm sorry not to have any more ideas what I can do from the distance.
Maybe playing with the ACAD.EXE.CONFIG might be a help, but I have not the environment with a ACAD2010x32 installed on a 64bit OD. The only thing I can say is that development/debugging in Win7x64 with VS2013 and Civil3D2010 (which is 32bit as there was no 64bit version availaible) does work well.
Sorry, - alfred -
Alfred NESWADBA
Valued Contributor
wbdehaan
Message 14 of 18 (205 Views)
03-23-2014 11:50 PM in reply to: Alfred.NESWADBA
Hi Alfred,
thanks for your effort, I will try to install a previous version of VBE (because debugging Autocad2010 with VBE 2008 worked well), or maybe try the installation on a different computer)
Valued Contributor
wbdehaan
Message 15 of 18 (195 Views)
03-24-2014 06:51 AM in reply to: wbdehaan
Hi Alfred,
When I use autoCad 2014 (64bit installed on 64Bit machine) and VBE 2013, i'm still not able to debug...and it seems like the project isn't loaded, when I use netload in AutoCad.
tried:
- http://through-the-interface.typepad.com/through_the_interface/2013/11/debugging-autocad-using-visua...
  1. Turn on “Use Managed Compatibility Mode” via Tools –> Options –> Debugging.
  2. Turn on “Enable native code debugging” from Project –> Properties –> Debug.
also tried:
- Loading accoremgd.dll, then it gives lot's of warnings:
Warning 1 The primary reference "accoremgd" could not be resolved because it has an indirect dependency on the .NET Framework assembly "mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. testproject
> tried rebuilding project:
maybe there's a solution to this, and otherwise i'll ask the system operator for installing an older version of VBE, 2012 or maybe back to the working 2008 version. Thanx in advance,
Alfred.NESWADBA
Message 16 of 18 (181 Views)
03-24-2014 09:30 AM in reply to: wbdehaan
can you upload a (small) sample project?
I try to start this on my system, do the corrections, if necessary, and send it back ... for you to try.
- alfred -
Alfred NESWADBA
Valued Contributor
wbdehaan
Message 17 of 18 (164 Views)
03-25-2014 12:17 AM in reply to: Alfred.NESWADBA
Hi Alfred,
in this mail there is an attachment with a small "hello world"-msgbox project
When I netload this project (the debug-version), it first gives me a warning about not trusted* project, I choose Load
* added d:\vbet\ to my trustedpaths, but seems like it doesn't read the subdir's inside, so i added the complete path to the dll, that works)
then it doesn't start the program, like it does on AutoCad2010.
below the added code in de class1.vb, with a breakpoint on 'Dim Temptext ..'
Imports Autodesk.AutoCAD.Runtime
Public Module testModule
    <CommandMethod("testprog")> Public Sub main()
        Dim TempText As String = "Hello World"
        MsgBox(TempText)
    End Sub
End Module
For your information:
- Menu Tools > Options > Debugging > Use Managed Compatibility mode = checked
- Solution Explorer > My Project > Menu Debug > checkbox Enable native code debugging = unchecked
Solution Explorer > My Project > Menu References > add dll Microsoft ActiveX Data Objects 6.1, because of future connection with SQL-server, is not neccessary at this moment,
kind regards
Wouter
Valued Contributor
wbdehaan
Message 18 of 18 (144 Views)
03-28-2014 04:31 AM in reply to: wbdehaan
Hi Alfred,
finally i found a solution. I downgraded my Visual Basic Express 2013 to Visual Basic Express 2010, and still debugging didn't work at begin. Then I found a solution from Kean Walmsley:
http://through-the-interface.typepad.com/through_the_interface/2010/04/hitting-breakpoints-in-net-cl...
and used solution 2:
"The cause of the problem boils down to the fact that VS 2010 does not choose the right version of the debugger for Class Library projects targeting prior versions of the .NET Framework: it always uses the default version, the debugger targeting v4 of the .NET Framework. This debugger doesn’t see breakpoints in projects targeting older versions of .NET."
Solution 2
Modify the config file of the exe that loads your AddIn (acad.exe.config, revit.exe.config, etc) so that it contains the following just before the
</configuration>
<startup>
  <supportedRuntime version="v2.0.50727" />
</startup>
that worked! Now I can try to do the same when using VBE2013.
Using AutoCad 2010 (installed as 32bit on a 64bit machine, using Windows 7)
thanks for all your effort!
kind regards
Wouter
