.NET
350 Views, 2 Replies
debug .net
Hello to all,
I'm trying to debug a sample from the map 3d
objectARX and i'm using visual studio 2003 , when I'm start debugging I see
the start window of AutoCAD and the debug mode exit without any errors.
I'm using AutoCAD civil 3D 2006 .
I'll appreciate it if anyone can help.
thank you all,
Danny
2 REPLIES 2
I bet you have .NET framework2.0 installed. By default Acad ObjectARX .NET
API uses latest .NET framework. You need to have Acad use .NET1.1 inorder to
debug it with VS2003.
You need to edit file "acad.exe.config" in acad installation folder
("Drive:\Autodesk\Acad2006" for example.
"autodesk.autocad.customization.dotnet" wrote in
message news:5206389@discussion.autodesk.com...
Hello to all,
thank you all,
Danny
thank you : )
"Norman Yuan" wrote in message
news:5206505@discussion.autodesk.com...
Hello to all,
thank you all,
Danny
”Boost
