.NET
Dealing with objects in LOCKED layer
3 REPLIES 3
dynamicscope
3269 Views, 3 Replies
Hi
I am trying to assign objects (only in UNLOCKED layers) with a new layer.
So basically, the user will select all the objects in the drawing.
After selecting (ex. press enter after window selecting), only objects in UNLOCKED layers will have a new layer.
Following is the code I am using...
But I keep getting eOnLockedLayer exception.
How should I handle this issue?
   using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
                PromptSelectionOptions pSelOpts = new PromptSelectionOptions();
                pSelOpts.MessageForAdding = "Select all objects";
                PromptSelectionResult pSelRes = acDoc.Editor.GetSelection(pSelOpts);
                if (pSelRes.Status == PromptStatus.OK)
                    SelectionSet acSSet = pSelRes.Value;
                    foreach (SelectedObject acSSObj in acSSet)
                        if (acSSObj != null)
    // This line I am getting eOnLockedLayer exception
                            Entity acEnt = acTrans.GetObject(acSSObj.ObjectId, OpenMode.ForWrite) as Entity;
                            if (acEnt != null)
                                acEnt.Layer = "newLayer";
                                acEnt.ColorIndex = 20;
                acTrans.Commit();
3 REPLIES 3
kdub_nz
in reply to: dynamicscope
Just stop them being selected
// Autodesk.AutoCAD.EditorInput.PromptSelectionOptions
public bool RejectObjectsOnLockedLayers
Regards
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
...or check the full syntax for TransAction.GetObject:
Public Overridable Function GetObject(id As Autodesk.AutoCAD.DatabaseServices.ObjectId, mode As Autodesk.AutoCAD.DatabaseServices.OpenMode, openErased As Boolean, forceOpenOnLockedLayer As Boolean) As Autodesk.AutoCAD.DatabaseServices.DBObject
     Member von Autodesk.AutoCAD.DatabaseServices.Transaction
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
ForceOpenOnLockedLayer Parameter,
That sure helped me. Thanks!Smiley Happy
”Boost
