.NET
Dealing with Keywords but also alllowing double and return key enter as well
1 REPLY 1
ralstogj
317 Views, 1 Reply
Hi
I am trying to get my code to work more like some of the built in autocad commands below is the code I have come up with. However if the string returned is not a Keyword or a string that can be converted to a double it is then not acceptable input. How do I jump back to re ask for the input. I could use goto I guess but thats not good practice is there a better way?
'ask the user if they want to accept the sureface level at the lid level or enter a new one
Dim acDoc AsDocument = Application.DocumentManager.MdiActiveDocument
Dim pKeyOpts AsPromptKeywordOptions = NewPromptKeywordOptions("")
Dim CurrentLidLevel AsDouble = oStructure.RimElevation
            pKeyOpts.Message = vbLf &
"Structure Lid Level:" & CurrentLidLevel
            pKeyOpts.Keywords.Add(
"Surface")
"New")
'pKeyOpts.Keywords.Default = "New"
            pKeyOpts.AllowNone =
True
Dim pKeyRes AsPromptResult = acDoc.Editor.GetKeywords(pKeyOpts)
SelectCase pKeyRes.StringResult
Case"Surface"
'Do nothing
                    Lidlevel = CurrentLidLevel
Case"New"
'ask user for grade to use
                    Lidlevel = acDoc.Editor.GetDouble(vbCrLf &
"Enter New lid level of Structure").Value
Case""
'Enter key hit
                    MsgBox(
"using surface level for lid level")
Case Else
'Check if input was a number that we can work with
Try
Double.TryParse(pKeyRes.StringResult, Lidlevel)
Catch ex AsException
EndTry
'enter pressed do nothing
EndSelect
Regards
Justin Ralston
http://c3dxtreme.blogspot.com/
1 REPLY 1
chiefbraincloud
in reply to: ralstogj
Use GetDouble with PromptDoubleOptions and AutoCAD will automatically reprompt if the user enters anything that is not a double or a keyword.  Setting AllowNone = true allows the Enter Key.
”Boost
