.NET
Active Contributor
0 Kudos
Post 1 of 13
DBMODE?
141 Views, 12 Replies
03-25-2008 10:09 AM
Wondering how this can be possible.
According to the online help:
DBMODE (System Variable)
Type: Integer
Saved in: Not-saved
Initial value: 0
Indicates the drawing modification status. The setting is stored as a bitcode using the sum of the following values:
1 Object database modified
4 Database variable modified
8 Window modified
16 View modified
32 Field modified
The DBMOD value is reset to 0 when you save the drawing.
I'm checking the value of DBMODE in my program before running some code. The Drawing is new, the action performed is a "Zoom Extents", so I presume the value should be 24 (8+16).
The value I read in the debugger is 23, and if I check in AutoCAD with no program running, simply with the Variable Editor, here's the result.
Anyone knows how to explain this?
René
*Tony Tanzillo
Post 2 of 13
Re: DBMODE?
03-26-2008 06:36 AM in reply to: ReneRam
I'm not sure what needs explaining other than that when you test a bit-encoded value, you mask out the bits you don't care about, so I guess at this point, the question is, what is it that you want to know?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:5884834@discussion.autodesk.com...
Type: Integer
Saved in: Not-saved
Initial value: 0
8 Window modified
16 View modified
32 Field modified
René
Active Contributor
0 Kudos
Post 3 of 13
Re: DBMODE?
03-26-2008 07:43 AM in reply to: ReneRam
It's a real simple question, how can you get "23"? as displayed in the attached image.
Since the value of DBMODE is the SUM of the following integers 1,4,8,16,32.
*Art Cooney
Post 4 of 13
Re: DBMODE?
03-26-2008 11:02 AM in reply to: ReneRam
But, it's not the sum of just those. The second bit (i.e. 2) is also used,
it just isn't documented (I don't know why). The second bit indicates that
a symbol table has been modified.
wrote in message news:5885876@discussion.autodesk.com...
attached image.
Active Contributor
0 Kudos
Post 5 of 13
Re: DBMODE?
03-26-2008 02:10 PM in reply to: ReneRam
Thanks Art,
as I said in my first post. the only information I had was from the online help of AutoCAD.
René
*Tony Tanzillo
Post 6 of 13
Re: DBMODE?
03-26-2008 03:24 PM in reply to: ReneRam
Not every bit is is documented (for various reasons, including that non one bothered to update the docs).
In the case of bit-encoded values, that means that some bits may not be documented, but when you work with bit-encoded values, you don't have to concern yourself with undocumented/uninterested bits in any case, because you have to mask them out.
Active Contributor
0 Kudos
Post 7 of 13
Re: DBMODE?
04-18-2008 06:48 AM in reply to: ReneRam
autocad starts counting at 0 zero so 24 (8+16) = 23
Distinguished Contributor
3 Kudos
Post 8 of 13
Re: DBMODE?
04-20-2008 03:38 PM in reply to: ReneRam
Wrong. The correct answer has already been posted.
Active Contributor
0 Kudos
Post 9 of 13
Re: DBMODE?
04-25-2008 04:25 AM in reply to: ReneRam
the answer may have been posted, but Autocad does count from zero.
3 Kudos
Post 10 of 13
Re: DBMODE?
04-27-2008 04:09 PM in reply to: ReneRam
You're answer is wrong and contradicts the correct answer posted.
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
