.NET
Valued Contributor
ProfWolfMan
Message 1 of 2 (291 Views)
Datagridview in palette -'ESC' key problem
291 Views, 1 Replies
05-21-2012 08:00 PM
Hi all,
I placed a datagridview on my toolpalette.
Normaly when we press 'esc' key while we are editing in the cell, cell value restore to original.
But in my palette, the cell do not get original value.
If i placed on separate 'windows application', it works perfect.
Where i am wrong?
Anybody face the same issue?
Any hint will help me lot.
I am using VisualStudio.net 2008, .net framework 3.5SP1,AutoCAD2011.
Thanks for looking.
Thanks & Regards,
G
ADN Support Specialist
Balaji_Ram
Message 2 of 2 (275 Views)
Re: Datagridview in palette -'ESC' key problem
05-22-2012 05:08 AM in reply to: ProfWolfMan
I have seen some keys that do not work with controls placed in the palette and I think it is because the palette does not pass them to the controls for appropriate handling.
A possible workaround could be to use the "KeyMessageFilter" to handle the escape key press and then pass it on to the data grid for cancelling the edit.
Here is the sample code, but it requires a bit more fine tuning. I have made the datagrid control as public to get easy access. I know its not neat :smileytongue:
Here is the sample code for the workaround :
	class KeyMessageFilter : System.Windows.Forms.IMessageFilter
		private const int WM_KEYDOWN = 0x100;
		static private MyUserControl _uc;
		public void SetUserControl(MyUserControl uc)
			_uc = uc;
		bool System.Windows.Forms.IMessageFilter.PreFilterMessage(ref System.Windows.Forms.Message m)
			if (m.Msg == WM_KEYDOWN)
				Document doc = Application.DocumentManager.MdiActiveDocument;
				Editor ed = doc.Editor;
				// Check for the Escape keypress
				System.Windows.Forms.Keys kc = (System.Windows.Forms.Keys)(int)m.WParam & System.Windows.Forms.Keys.KeyCode;
				if (m.Msg == WM_KEYDOWN && kc == System.Windows.Forms.Keys.Escape)
					if (_uc.DataGridView1 != null && _uc.DataGridView1.IsCurrentCellInEditMode)
						_uc.DataGridView1.CancelEdit();
			return false;
	public class MyCommands : Autodesk.AutoCAD.Runtime.IExtensionApplication
		private KeyMessageFilter _filter;
		static Autodesk.AutoCAD.Windows.PaletteSet _palette;
		[CommandMethod("ShowPalette")]
		public void ShowPalette()
			if (_palette == null)
				_palette = new Autodesk.AutoCAD.Windows.PaletteSet("PaletteCmd", new Guid("{95BC5096-54DA-408a-836B-8969145A4F85}"));
				_palette.Style = PaletteSetStyles.ShowAutoHideButton | PaletteSetStyles.ShowCloseButton | PaletteSetStyles.Notify | PaletteSetStyles.Snappable;
				_palette.Text = "Test";
				_palette.Add(null, _uc);
			_palette.Visible = true;
		private void IExtensionApplication_Initialize()
			Document activeDoc = Application.DocumentManager.MdiActiveDocument;
			Database db = activeDoc.Database;
			Editor ed = activeDoc.Editor;
			_uc = new MyUserControl();
			_filter = new KeyMessageFilter();
			_filter.SetUserControl(_uc);
			System.Windows.Forms.Application.AddMessageFilter(_filter);
		private void IExtensionApplication_Terminate()
			System.Windows.Forms.Application.RemoveMessageFilter(_filter);
Balaji
Developer Technical Services
Autodesk Developer Network
