.NET
norman.yuan
Message 11 of 13 (249 Views)
Re: Database.Save "eFileSharingViolation"
04-02-2012 07:02 AM in reply to: Alexander.Rivilis
Well, I'd think how an empty database is created (with noDocument argument being true/false) should not have effect on ReadDwgFile() method being called and the Database being saved as logically. But I could be wrong.
Anyway, I tested with
using (Database db = new Database(false, true))
The result were the same:
Acad2009 32bit: OK;
Acad2011 32bit: getting eFileSharingViolation exception
Acad2012 64bit: getting eFileSharingViolation exception
Since it is very unlikely this would have anything to do with 32/64bit, I'd think this is bug/break in Acad 19.xx (2010/11/12)
Except for OpenFileMode.OpenForreadAndWriteNoShare in ReadDwgFile() method, the other value of FileOpenMode (OpenForReadAndAllShare, OpenForreadAndReadShare and OpenTryForReadShare) seems OK.
So, if I'd avoid to use OpenFileMode.OpenForReadAndWriteNoShare, if I have to read dwg file into database in in the same time do not want the dwg file accessed by others.
Moderator
Alexander.Rivilis
Message 12 of 13 (248 Views)
04-02-2012 07:09 AM in reply to: norman.yuan
A small remark. 19.xx - is AutoCAD 2013 ..., but 18.xx is 2010,2011,2012
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Valued Mentor
kevin.barnett
Message 13 of 13 (118 Views)
10-02-2013 11:00 PM in reply to: Hallex
Hallex saved me yet again ... thx for this post...
