.NET
Database.Save "eFileSharingViolation"
12 REPLIES 12
Message 1 of 13
5658 Views, 12 Replies
Need some help here:
Any clue why I'm getting this error?
  Sub LoopThroughFolderOfDwgsAndUpdateHyperlinks()
        Dim myCounter As Integer = 0
        ' First create a FolderBrowserDialog object
        Dim FolderBrowserDialog1 As New FolderBrowserDialog
        ' Then use the following code to create the Dialog window
        ' Change the .SelectedPath property to the default location
        With FolderBrowserDialog1
            ' Desktop is the root folder in the dialog.
            .RootFolder = Environment.SpecialFolder.Desktop
            ' Select the C:\Windows directory on entry.
            .SelectedPath = "Q:\"
            If .ShowDialog = DialogResult.OK Then
                ' Display the selected folder if the user clicked on the OK button.
                Dim files() As String = Directory.GetFiles(.SelectedPath, "*.dwg", SearchOption.TopDirectoryOnly)
                For Each file In files
                    'do code to files
                    If (System.IO.File.Exists(file.ToString)) Then
                        'Try
                            'Create Database Object to Store Drawing Info into
                            Dim myDB As New DatabaseServices.Database
                            'Read Drawing File
                            myDB.ReadDwgFile(file, FileOpenMode.OpenForReadAndWriteNoShare, False, "")
                            'TODO: Error Catching for files already opened...
                            'UPDATE THE HYPERLINKS IF FILE OPENS
                            UpdateHyperlinksInDocument(myDB)
                            'Processed File Count
                            myCounter = myCounter + 1
'!!!!!!!!!!ERRROR ON THIS LINE "myDB.SaveAs"
                            'Save Drawing
                        myDB.SaveAs(file, False, DwgVersion.Current, myDB.SecurityParameters)
                            'File Processed Successfully
                            gsFileSuccessList.Add(file)
                            'Clean-up Memory Object
                            myDB.Dispose()
                        'Catch ex As Exception
                        '    Debug.Print(ex.Message & "On file:" & file)
                        '    gsFileErrorList.Add(file)
                        'End Try
                    Else
                        Debug.Print("Can't Find and Open File : " & file)
                    End If
                Next
            End If
        End With
        MsgBox("Processed: [" & myCounter & "] AutoCad files" & vbCrLf & _
              "Succesfully Added: [" & gintHyperlinkCounter & "] hyperlinks")
        If gsFileSuccessList.Count > 0 Then
            Dim sFileList As String = String.Empty
            For i = 0 To gsFileSuccessList.Count - 1
                sFileList = sFileList + (gsFileSuccessList.Item(i) & vbCrLf)
            Next
            MsgBox("Successfully processed the following files: " & vbCrLf & _
                    sFileList)
        End If
        If gsFileErrorList.Count > 0 Then
            For i = 0 To gsFileErrorList.Count - 1
                sFileList = sFileList + (gsFileErrorList.Item(i) & vbCrLf)
            Next
            MsgBox("Couldn't Process the following files: " & vbCrLf & _
                    sFileList)
        End If
    End Sub
12 REPLIES 12
Message 2 of 13
Hallex
                 Try to use this line instead :
                       'Read Drawing File
           myDB.ReadDwgFile(file, FileShare.ReadWrite, False, "")
                And also this line may different syntax relative to your Acad version:
                        'Save Drawing
                Try instead:
                       myDB.SaveAs(file, False, DwgVersion.Current)
~'J'~
Message 3 of 13
Hallex
If this would be interesting for you:
Here is your working code , I've just changed inner Sub for test
(currently I changed one attribute for all title blocks in modelspace)
It's working good on A2010 both Debug and Release mode
        Public Shared Sub LoopThroughFolderOfDwgsAndUpdateHyperlinks()
                .SelectedPath = "C:\MyDirectory\MyFolder"
                    Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
                    Using docloc As DocumentLock = doc.LockDocument
                            'do code to files
                            If (System.IO.File.Exists(file)) Then
                                Try
                                    Using myDB As Database = New Database
                                        'Read Drawing File
                                        UpdateHyperlinksInDocument(myDB)'
                                        'ChangeTitleBlock(myDB)'<-- used for test
                                        'Save Drawing
                                        'myDB.Dispose()
                                    End Using
                                    MsgBox(ex.Message & "On file:" & file & vbLf & "Trace: " & vbLf & ex.StackTrace)
                                End Try
                            Else
                                MsgBox("File does not existse:" & file)
                            End If
                        Next
                    End Using
                End If
            End With
            'MsgBox("Processed: [" & myCounter & "] AutoCad files" & vbCrLf & _
            '      "Succesfully Added: [" & gintHyperlinkCounter & "] hyperlinks")
                Next
                        sFileList)
            End If
                Next
                        sFileList)
            End If
        End Sub
~'J'~
Message 4 of 13
in reply to: Hallex
Hallex thanks for taking the time to test out my code!
Still no luck on my end.
I get A first chance exception of type 'System.NullReferenceException' occurred in ClassAutocad2011.dll
and then now I get,
FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 138e9e2bh
Using Autocad 2011, Visual Studio 2008, Win XP 32-bit
Hmm.... I'll keep trying.
Message 5 of 13
Hallex
Seems to me the problem is on your sub routines
Try in Debug mode set Option Strict to On, then hit
Build Solution I'm sure you will be see some errors
in the Errors window
After you will fix them all set Option Strict to Off back
and try again
I've tested code on Win 7 VS 2010
Sorry  I have not have any other ideas
~'J'~
Message 6 of 13
in reply to: Hallex
Got it working! YEAH!
  <CommandMethod("runbatch")> _
    Sub ProcessFolderPath()
        '<<FOLDER DIALOGUE------------------------------------------------------------------
        Dim myFolderPath As String = ""
            ' Prompt the user with a custom message.
            .Description = "Select the directory of P&ID Drawings"
                myFolderPath = .SelectedPath
                LoopThroughFilesInDirectory(myFolderPath, SearchOption.TopDirectoryOnly)
            Else
                Exit Sub
            End If
        End With
    End Sub
    Sub LoopThroughFilesInDirectory(ByVal myFolderPath As String, ByVal mySearchOption As SearchOption)
        '<<Loop Through Files------------------------------------------------------------------------------------
        Dim files() As String = Directory.GetFiles(myFolderPath, "*.dwg", mySearchOption)
        For Each File In files
            'Debug.Print("Processing File: " & File & Environment.NewLine)
            ProcessFile(File, eBlockScripts.UpdateHyperlinksInDrawing)
        Next
    End Sub
    <CommandMethod("eatthiscat")> _
Sub eatthiscat()
        ProcessFile("C:\cat.dwg", eBlockScripts.UpdateHyperlinksInDrawing)
    End Sub
    Sub ProcessFile(ByVal myFile As String, ByVal ProcessAction As eBlockScripts)
        'Detect if File Exists
        If System.IO.File.Exists(myFile) = True Then
            'ED_VBNET.WriteMessage(myFile & Environment.NewLine)
        Else
            ED_VBNET.WriteMessage("Can't find file: " & myFile & Environment.NewLine)
            Exit Sub
        End If
        '<< Modify Files ----------------------------------------------------------------------------------------
        Using myDB As New DatabaseServices.Database(False, True)
            'Read Drawing File
            myDB.ReadDwgFile(myFile, FileShare.ReadWrite, False, "")
            'Action to Accomplish to File
            UpdateLivelinkHyperlinksInDocument(myDB)
            'Save Changes to File
            myDB.SaveAs(myFile, DwgVersion.Current)
        End Using
    End Sub
    ''' <summary>
    ''' This Is a List of Common Script Actions to Apply to a Cad Drawing
    ''' </summary>
    ''' <remarks></remarks>
    Public Enum eBlockScripts
        NoAction
        InsertDrawingStamp
    End Enum
Message 7 of 13
Hallex
Good to hear it
Cheers Smiley Happy
~'J'~
Message 8 of 13
norman.yuan
Sorry to post against a question that seemed being solved for a quite while.
However, I think all the answers do not really solve the actual issue raised by the OP, although the OP made the code change as other suggested and seemed satisfied.
The real issue is the enum type "Autodesk.AutoCAD.DatabaseServices.FileOpenMode.OpenForReadAndWriteNoShare" used in the ReadDwgFile() method causes AutoCAD crash. All the suggestions in the replied post uses the overloaded ReadDwgFile() method with System.IO.FileShare.ReadWrite for the second argument.
AFAIK, the overloaded ReadDwgFile() method with Autodesk.AutoCAD.DatabaseServices.FileOenMode argument was introduced into Acad's .NET API in version 18.x (2007/8/9, but I am not sure which one. I only have Acad2009 as oldest Acad available). All my code where ReadDwgFile() is needed uses System.IO.FileShare, because the code was written against Acad2006 and I never thought I need to update the code.
After seeing the OP, being curoius, I wrote following simple code to try to find why using FileOpenMode causes Acad crash:
public class Commands
    [CommandMethod("FileOpenMode")]
    public static void OpenFileModeTest()
        //A simple drawing file
        string dwgFile = @"C:\Work\Acad\SomeDrawing.DWG";
        Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
        using (Database db = new Database(false, false))
            try
                //read dwg file
                db.ReadDwgFile(dwgFile, FileOpenMode.OpenForReadAndWriteNoShare, false, null);
                //Does nothing but immediately save the database
                db.SaveAs(dwgFile, DwgVersion.Current);
            catch (System.Exception ex)
                ed.WriteMessage("\nError: {0}", ex.Message);
 As we can see, the code is very simple: just call ReadDwgFile() and then Database.SaveAs(). Then I tried it with differnt AutoCAD version:
Acad2009, 32bit - the code runs OK. That is, the Database is successfuly saved back.
Acad2011, 32bit - The Database.SaveAs() throw "eFileSharingViolation" error.
Acad2012, 64bit - the same "eFilesharingViolation" error, in 2 different computers.
Of course, when tried with Sytem.ID.FileShare.ReadWrite parameter in ReadDwgFile(), Database.SaveAs() runs OK with all Acad versions I tested.
When doing the test, the drawing file is from my local HD, absolutely no other Acad instance is accessing it for sure.
To me, it is quite obvious: Acad version 19.x (2010/2011/2012, although I do not have Acad2010 at hand, but I'd be willing to bet on it) breaks the ReadDwgFile() with FileOpenMode.OpenForReadWritenoShar argument.
BTW, I did not test with other FileOpenMode value, because it seems the OpenForReadWriteNoShare value should be the direct reason of the trouble.
Can anyone verify this with your Acad version? Since Acad2013 has been released,can someone verify this with Acad2013 (bother 32bit/64bit)?
Norman Yuan
Drive CAD With Code
Message 9 of 13
Try:
using (Database db = new Database(false, true))
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 10 of 13
Thanks for the tip Norman!
So the input parameter fileopenmode.
I'm on autocad 2011 win xp.
So this makes sense. It's working so far.
Message 11 of 13
Well, I'd think how an empty database is created (with noDocument argument being true/false) should not have effect on ReadDwgFile() method being called and the Database being saved as logically. But I could be wrong.
Anyway, I tested with
The result were the same:
Acad2009 32bit: OK;
Acad2011 32bit: getting eFileSharingViolation exception
Acad2012 64bit: getting eFileSharingViolation exception
Since it is very unlikely this would have anything to do with 32/64bit, I'd think this is bug/break in Acad 19.xx (2010/11/12)
Except for OpenFileMode.OpenForreadAndWriteNoShare in ReadDwgFile() method, the other value of FileOpenMode (OpenForReadAndAllShare, OpenForreadAndReadShare and OpenTryForReadShare) seems OK.
So, if I'd avoid to use OpenFileMode.OpenForReadAndWriteNoShare, if I have to read dwg file into database in in the same time do not want the dwg file accessed by others.
Norman Yuan
Drive CAD With Code
Message 12 of 13
A small remark. 19.xx - is AutoCAD 2013 ..., but 18.xx is 2010,2011,2012
Expert Elite Member
Message 13 of 13
kbarnettza
in reply to: Hallex
Hallex saved me yet again ... thx for this post...
”Boost
