.NET
.NET
Distinguished Contributor
wesbird
Message 1 of 2 (165 Views)
Database.Filename return autosave filename .sv$
165 Views, 1 Replies
09-05-2013 12:12 PM
  here is my code
public static class Active
    public static Document Document
        get { return Application.DocumentManager.MdiActiveDocument; }
    public static Database Database
        get { return Document.Database; }
    public static string Name
        get { return Database.Filename; }
 Active.Name some return the autosave filename, e.g.
C:\Documents and Settings\Davisas\local settings\temp\TDB0157-006A-FP00_1_1_1030.sv$
the correct one should be
C:\Documents and Settings\Davisas\local settings\temp\TDB0157-006A-FP00.dwg
Is this a bug? how to avoid it?
Thank you so much.
Wes
Vault Pro 2014, Windows 7 64 bit, AutoCAD (ACA, Map) 2014
No bug... the database is after the autosave associated to the temp file... so the answer from the database is correct.
You should use the name of the document instead. This would give you the desired Information.
get { return Document.Name; }
Matti72
Message 2 of 2 (142 Views)
Re: Database.Filename return autosave filename .sv$
09-06-2013 02:18 AM in reply to: wesbird
