.NET
Data extraction by layer
5 REPLIES 5
1437 Views, 5 Replies
Hi, I just discovered that I can extract data from autocad and that is making my work easier. There is just one thing I wish I could do to fully parameterize the extraction. I'm trying to add the lenghts of all the polylines that exist in each layer. I can extract all of them and sort them by layer, but I haven't figured out a way to automatically add them to get the total lenght by layer. Is there a way that I can do this?
Thank you!
5 REPLIES 5
SENL1362
create dictionary <string, double>. key==layerName, value += each poly length
after collecting each length write the total length for each layer.
You can print the grand total using myDict.Values.Sum().
SENL1362
in reply to: SENL1362
                var plLayers = new Dictionary<string, double>(StringComparer.OrdinalIgnoreCase);
                using (Transaction tr=db.TransactionManager.StartTransaction())
                    BlockTableRecord ms=(BlockTableRecord)tr.GetObject(SymbolUtilityServices.GetBlockModelSpaceId(db),OpenMode.ForRead);
                    foreach (ObjectId id in ms)
                        if (id.ObjectClass.DxfName == "LWPOLYLINE")
                            var pl = tr.GetObject(id, OpenMode.ForRead) as Polyline;
                            if (pl != null)
                                if (!plLayers.ContainsKey(pl.Layer))
                                    plLayers.Add(pl.Layer, 0);
                                plLayers[pl.Layer] += pl.Length;
                    tr.Commit();
                if (plLayers.Count > 0)
                    foreach (var kvp in plLayers.OrderBy(kvp => kvp.Key))
                        ed.WriteMessage("\n {0}=={1}", kvp.Key, kvp.Value);
                    ed.WriteMessage("\n Total Length== {0}", plLayers.Values.Sum());
_gile
If you prefer a more functional / declarative way of writing using Linq:
        public Dictionary<string, double> GetPlineLengthsbyLayer(Database db)
            RXClass plineclass = RXClass.GetClass(typeof(Polyline));
            using (Transaction tr = db.TransactionManager.StartOpenCloseTransaction())
                return
                    ((BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForRead))
                    .Cast<ObjectId>()
                    .Where(id => id.ObjectClass == plineclass)
                    .Select(id => (Polyline)tr.GetObject(id, OpenMode.ForRead))
                    .GroupBy(pl => pl.Layer)
                    .ToDictionary(grp => grp.Key, grp => grp.Select(pl => pl.Length).Sum());
Gilles Chanteau
GileCAD
GitHub
SENL1362
in reply to: _gile
Nice Gile
in reply to: _gile
thank you!
”Boost
