.NET
FRFR1586
Message 1 of 1 (89 Views)
cut/paste problem when an object is referencing in dictionary by his objectid
89 Views, 0 Replies
06-25-2014 08:36 AM
I have a problem with a new software
the program ask the user for selecting some objects,
  then create a namedobjectdictionary (NOD) ,
  then add an extension dictionary to this NOD,
  finally , add one xrecord for each dbobjects
each xrecord contains the objectid of the object and some personal informations
after this , it is not possible to cut and paste (or copy) the dbobjects with Autocad
it is possible to copy them with the copy command , or using the design center
If I suppress the xrecord , the cut/paste work fine
the extension dictionay use the treatelementashard =true
so where is the problem ? my program or autocad or other ?
attached , you can find a dwg with problematic objects , and my source project
thanks in advance
Luc
