I am trying to display advanced information about an item (witch is a block reference, witch has some XData that points to an inventory item in our database) in a tooltip (like a picture of the item, some data about its manufacturer)... in other words, I would like to display a form (WinForm, WPF, HTML, ... anything...) as a tooltip. Is this possible with in .Net?
2 options seems plausible to me :
Is this statement correct : It is not possible with AutoCAD's .Net API to reproduce the default rollover tooltips' content (including the little color box for the layer - or any other content other than text).
Any help would be appreciated!
Solved by caddzone. Go to Solution.
That's correct.
Autodesk completely dropped the ball on that one - the WPF-based
rollover tooltips are not customizable at all, and the 'drafting' tooltip
only displays text.
You can implement your own tooltip that appears in place of the
drafting tooltip, by disabling the latter, and handling the rolllover
event.
Alright thanks.......
This is very disapointing..... But as you said, I will simply create a fake one to do what I want it to do.
Tanks alot for the VERY quick response ! 🙂
Good day
