.NET
vasantpadhiyar71
Message 1 of 6 (285 Views)
Customization with AutoCAD-LT 2011 and +
285 Views, 5 Replies
04-01-2013 12:07 AM
Hi All,
I want to Customize AutoCAD-LT.
Is there any way to Customize it:
Using ObjectARX, VBA, LISP or any..
Vasant PADHIYAR
Vasant PADHIYAR
vasantpadhiyar71 wrote:
...Is there any third party developer tool using which I can cutomize AutoCAD-LT using ObjectARX or AutoLISP?...
 From ObjectARX License:
... You may not use the Software to develop applications for AutoCAD LT®, DWG TrueConvert™, and DWG TrueView™ software, as the aforementioned products are nonextensible applications and the use of the Software to develop applications for these products is expressly prohibited by this Agreement...
So even discuss the possibility of using such kinds of customization for AutoCAD LT seems unacceptable in this official forum.
Hi All,
The conclusion is that As AutoCAD LT is light version of AutoCAD, it does not support Customization ans we should not think for customization in AutoCAD-LT.
Thanks All
Vasant
Alfred.NESWADBA
Message 2 of 6 (269 Views)
Re: Customization with AutoCAD-LT 2011 and +
04-01-2013 01:17 AM in reply to: vasantpadhiyar71
LT has no API (and is explicitly made for no application base, that's also one of the arguments why it's price is much lower than the full version).
You may use some scripting, but no .net/c++/com-based development
Sorry, - alfred -
Alfred NESWADBA
vasantpadhiyar71
Message 3 of 6 (256 Views)
04-01-2013 01:42 AM in reply to: Alfred.NESWADBA
Thanks Alfred,
Thanks- Vasant
Vasant PADHIYAR
Alfred.NESWADBA
Message 4 of 6 (248 Views)
04-01-2013 03:45 AM in reply to: vasantpadhiyar71
As LT has no API .... you can't develop ARX or LISP applications, so also no developer can do that.
If your question is that there are applications out there that simulate LISP or ObjectARX on LT, than may be. I know one case of a LISP-interpreter that was running on top of LT (making it possible to run LISP-tools/applications on LT), in that case Autodesk was going to court with that company (that created that LISP-interpreter) as Autodesk sees that as against the license rules. My personal opinion: don't try that or at least ask a lawyer first, it's critical.
- alfred -
Alfred NESWADBA
Moderator
Alexander.Rivilis
Message 5 of 6 (244 Views)
04-01-2013 04:53 AM in reply to: vasantpadhiyar71
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
vasantpadhiyar71
Message 6 of 6 (227 Views)
04-01-2013 06:55 AM in reply to: Alexander.Rivilis
Hi All,
Thanks All
Vasant
Vasant PADHIYAR
