The way you use a treeview in AutoCAD isn't much different from the way you
do it in a windows application.
But, to do that, you have to be reasonably familar building AutoCAD
applications using .NET, and it's fairly obvious from your questions that
you've never done that before.
Using .NET and AutoCAD's ObjectARX API is something that requires some
learning and experience, which is why I pointed you at that site.
It seems that you're looking for an 'easy button'. Sorry to disappoint, but
there is none.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6292455@discussion.autodesk.com...
Hi Tony thanks for the reply.. i have go through the site, but i have to
ask, is there any API thing, that i can build a treeview in AutoCAD 2010
instead of building a windows application of treeview? thanks
